Perrin PSRS Discontinued?
Old Jun 29, 2015 | 09:01 PM
Grimgrak's Avatar
Wrong KCA400M is listed for the EVO X and it only adds 0.5 caster where as the perrin added 3.0 so no it's not nearly the same.
Originally Posted by Ang Wen Yan
Whiteline KCA400M is same as PSRS
Old Jun 29, 2015 | 09:50 PM
kaj's Avatar
kaj
VIII/IX/X Are all the same, IIRC. But that sure is a reduction in caster.
Old Jun 30, 2015 | 04:07 AM
MRLancer05's Avatar
Yeah you definently don't get the same amount of caster with the Whiteline, but you do get more then stock. I DD the car and plan on using it to get my instructers licence. I don't need to extract every bit of performance out of the car.
Old Jun 30, 2015 | 05:04 AM
Terror Rising's Avatar
The PSRS does not add 3° of caster; it was supposed to be roughly 1.5°. Still more than the Whiteline kit, though.
Perrin's EvoM thread
The OEM bushings did allow flex for a compliant ride hence the reasoning behind the solid mounted spherical in both kits. Before I put in the Whiteline kit I was going back and forth between the two brands. I ended up with the Whiteline because I didn't want to have to cut up my subframe and I wanted the extra protection afforded by the boots.
Old Jun 30, 2015 | 09:43 AM
LetsGetThisDone's Avatar
My PSRS added exactly 1.5* on one side and 1.7* on the other, and I now have equal caster since it was off a bit stock. It was pretty cool to see the finished alignment with perfectly even toe/camber/caster..
Old Jul 5, 2015 | 10:02 PM
Lightsaber's Avatar
This.
Although I have been hoping to have more selections for our car.
bchappy
18
Aug 16, 2012 01:27 AM
PERRIN_JOHN
EvoX 'For Sale' Suspension / Brakes / Handling
Jul 14, 2009 09:17 AM
theshadow
Apr 30, 2009 07:59 AM
nala
Apr 4, 2009 03:01 AM
PERRIN_JOHN
Aug 16, 2008 09:38 AM
