R33 wheels on Evo 9 fitment help.
I've purchased a set of oem GT-R R33 wheels for my Evo IX.
Correct me on this:
Based on my research the wheels are 17", 5x114, 9j, et30, which is exactly what I was looking for. The problem is that the centre bore is 66.1.
The Evo 9 centre bore is 67.1
Will these wheels fit SAFELY with a bit of coaxing, or will I need to mill the bore on the wheels to 67.1?
Also, who is the manufacturer of these wheels? Enkei, BBS? Only info I can come up with is that they're forged wheels.
Correct me on this:
To be honest. There is literally zero in wheel choices for this car in 17" in South Africa. Especially not in the specs I was looking for. 17", 5x114, 9j, et30.
In my eagerness, having found this wheel in the correct spec, I must admit that the cb slipped my mind.
I can fix this, but I need confirmation that the above specs are indeed correct (66.1 R33 wheel bore and 67.1 Evo centre bore) and that it'll take just a little bit of machining to the bore on the wheel to get it to 67.1 for a perfect fit.
Turns out, they were 67.1 already. Strangely enough, the fronts fitted with no complaints, but at the rear we needed to use a pencil grinder to open up the bevelled edge just a tiny bit. They did this at the wheel shop.
