Brake issues
Old Jan 29, 2016 | 01:55 PM
audiofan's Avatar
Brake issues
HI,
I'm having some brake problems, I have no ABS since it is a RS model.
It seems like only one wheel is braking, so the car immediatly locks one wheel, and it get a little sideways, and brake perfoamnce is really poor.
I did a flush on the brake fluid, and same thing.
Next thing would be service the calipers, but what can it be? what should I check?
Old Jan 29, 2016 | 02:10 PM
juan.c.olivos's Avatar
When you flushed the fluid did you see if fluid came out properly in that brake line when you hit the brakes?
Old Jan 30, 2016 | 12:07 PM
audiofan's Avatar
well I didn't do it, but mechanic said everything looked fine.
Old Jan 31, 2016 | 01:44 PM
LetsGetThisDone's Avatar
Calipers could need rebuilt.
Old Jan 31, 2016 | 10:48 PM
Jonno99's Avatar
If a mechanic did it, why didn't he check the brakes? If you want to play with it yourself you need to take the wheels off and inspect the calipers, you should already know which one is working so look at the dicky one a d see if the caliper piston moves when you press on the peddle, don't push it all the way down and jam the calipers, you can easily lever the calipers back flush again, clean everything with brake clean
DrivelineSales
EvoX 'For Sale' Suspension / Brakes / Handling
Nov 5, 2009 03:40 PM
DrivelineSales
Evo 'For Sale' Suspension / Brakes / Handling
Sep 24, 2009 01:04 PM
Fizz Autosports
124
Sep 14, 2009 07:26 AM
DaWorstPlaya
Oct 21, 2008 09:47 AM
