Megan rear camber arms
Hello all, had a question about these http://www.meganracing.com/product.a...d=937&catid=96
How do you make the actual adjustment once its all bolted onto the car? Do you have to unbolt the threaded end, turn it, then bolt back in? Lastly, why 3 jam nuts? Megan doesn't provide any instructions with these. Any input from anyone with experience in using this would be appreciated. Thanks.
No, not at all. Not about any stance, just slightly more aggressive than stock. Got the arms because I wanted new bushings so why not adjustable. But I was looking at them and couldn't figure them out unless like I said, you unbolt it. I'm hoping I'm wrong here.
Once bolted on the car, you would have to unbolt the one end where it connects to the knuckle and rotate that end. The nuts are there to lock your adjustment in.
Another thing is since I see 3 nuts (all you need are 2 to lock them in), I'm guessing you don't have to unbolt anything at all. You loosen the nuts closer towards the center and the last one at the end spins the entire shaft for adjustment. You'll know once you get it.
p00shy
For Sale - Wheels / Tires / Suspension / Brakes
Apr 11, 2016 09:23 PM
AKW89
Mar 17, 2015 12:39 PM
Segfault
Aug 9, 2012 01:05 PM
TTP Engineering
Jul 6, 2009 03:38 PM
