Lowering the car, without sacrifice...?
Originally posted by ogvw
"Mttam510, hold you fire! Hold your fire....... I think you have demolished the entire thread!"
very well spoken sir, and thank you for the lesson.
I've been following the thread and even though I don't have the Evo yet, suspension will be one of my first mods and I'm interested in getting rid of the fender gap without losing any of the handling the car is known for.
So has anyone who's lowered the car actually lost some of the handling and what springs did you use? I thought someone on here with the Tein S springs ran it at the track and their lap times were better.
My Tanabe springs have been great. They seem to be a nice overall spring. I race my Evo in Solo II ESP. At the last autox I won ESP by 2.5 seconds. In the class there was a Z28 Camaro, WS6 T/A, and two other Evo's..one with Tein S Techs (placed 2nd) and one with coil overs (not sure brand)(placed 3rd).
Driving probably played the biggest part in the 2.5 second difference...but my Tanabes work great...
Originally posted by mttam510
??????????? If a damper has more valving that the spring, the car will "ratchet" itself down untill there is no "bump" travel left, a soft spring will NOT wear out a damper because the piston inside the shock is moving further in its available travel. It's still oils through holes and shims to dictate when this happens. As far as sweet spots go, unless you have position sensitinve dampers with bypass tubes, you can forget about that too....
Also what you are talking about with runing out of bump travel can only happen in a short range time, infact it would be the same sort of circumstance that would lead to shock fade...something that does occur even in more mundane areas like SoloII in shocks that dont posses enough dampening force to control the springs they are matted to.
*hand to ear* BEEP BEEP BEEP "hear that boys and girls? I think thats the sound of the bus backing up for Mttam510 to take Absinthe to school!"
By the way.....he was motorsports manager for "the" primier suspension manufacturer for 3 or so years, he may know a thing or two about dampers/springs
*bullet proof vest enabled*
Originally posted by absinthe
So you are saying that shock are not desigend to operate in a specific range, ie not position sensitive?
it is still oil though holes and seals but more action means more oil which traslates into faster ware if this were not the case you would not see bouncy civics with stock shock because the damper can operate effectively in any range so you can simply shrrten the springs fix the alignment and have a car that operates as if it were stock? .
I really support the forum and I think that there a lot of people out the with good information to share, but when one just begins to utter such foul BS....it really is not good for the forum....if your not sure, don't make it sound like you know what the hell your talkin' bout, because it is obvious that you don't....
DAMPING is what a strut or shock does, but DAMPENING is what occurs in your shorts after you **** yourself.....
On another note. The stock strutsare heavily dampened and the stock spring rates are considered mild. The harsh ride is from the heavy damping of the Struts.
Actually the harsh ride comes from the front bumpstops - which are designed into the spring curve. There is only about 1/4" of shock travel before you start using the bumpstops in an unmodified car.
Right? I almost searched for my old physics and statics and dynamics book before I got done reading the thread.
Whats the moral of THIS story?
Originally posted by expl0d
so is everyone here thats arguing in agreement that just using springs is a bad way to go??
