Front Strut Replacement Options IX MR
Ok. The only front option that I can find for the evolution are the Bilsteins. I have looked up non-MR, and the only KYB options coming up are for the rear only. Can you specifically tell me what to search to find the ones that are compatible? Thanks
Sorry that was the Bilstein, here is kyb MR554821https://mitsubishiparts.net/parts/20...&siteid=218241
The Bilsteins are 225 each, and that's just not in my single mom full time grad student budget right now. I'm now looking into a used stock set. After graduation I can replace with the Bilsteins. I just need something to get me through the next 6 months or so. Found a set on ebay, fingers crossed they work!
https://www.evolutionm.net/forums/sa...port-mach.html
Check this out, you will even get a spare rear shock. $150 plus shipping
I would be wary about struts with 90k miles. Mine all were done around 80-90k. They cannot be rebuilt so expect very little usage out of them. Also expect to replace them soon if they aren't already bad.
