Help with rotor problem?
Old Nov 4, 2017 | 07:24 PM
DsmEvo87's Avatar
Hi guys, got A lil problem with my brakes (did rotors&pads) about 3 weeks ago, but for some reason the inner of the rotor goes "untouched" by the pad kinda see rust for about a inch outer edge seems perfect inner edge doesn't touch :/
Piston stuck? air in system? I'm lost.
anything specific I should look for? thanks!
Old Nov 4, 2017 | 07:29 PM
With someone in the car, I would have them pump the brakes while you inspect using a flash light at the caliper. See if you can see the inner pad movement
If not, Yes, do a bleed. Hopefully thats all it is
If not, we will have to dig deeper!
Old Nov 4, 2017 | 07:33 PM
DsmEvo87's Avatar
thanks for quick reply! Will do that first thing in the morning! Happend with both my fronts rears are perfect!
fronts got almost an inch of inner edge rust (same rust as when u wash your car)
Old Nov 5, 2017 | 11:40 AM
DsmEvo87's Avatar
Pads are hawks hp street btw, te rotor facing the engine is completely clean, re-bled the system noting took out the pads you can see the inner spot where it's not having contact with the rotor :/
I have pics but dont know how to post
Old Nov 5, 2017 | 02:53 PM
barneyb's Avatar
Images are easy to post. Click on the icon that looks like a mountain. Go to wherever the picture file is on your computer and click it.
Old Nov 5, 2017 | 03:12 PM
^^^Thanks
Heres a more visual how-to.
https://www.evolutionm.net/forums/ev...e-hosting.html
Please post up!
EvO-LOui
Feb 2, 2015 06:50 PM
ZK
MitsubishiParts.net - WA
Jul 11, 2009 02:46 PM
ZyBeR
13
Aug 4, 2007 06:13 PM
Xska555
Feb 19, 2006 03:05 AM
Drazi
Aug 29, 2005 08:09 PM
