Enkei RPF1 Inquiry
Old Dec 12, 2017 | 10:09 AM
Jeff Langevin's Avatar
Enkei RPF1 Inquiry
Hey Guys, I'm contemplating getting a set of the RPF1 for my 2005 Evo 8, in the oem size of 17 x 8 with 35 mm offset, and runnin 235/45/r17 Yokohama Avid Envigors. The question I have is this; I know that they will clear the brakes, so that's not the issue in terms of needing spacers, however I am lowered on Tein Flex Z coilovers, and I'm wondering if there will be any issues with rubbing. I'm on the stock 8 enkei's right now and have no issues, so I just wanted to confirm before I make the jump to these.
Thanks for any input!
UPDATE: disregard, putting in Wheels Fitment thread!
Old Dec 12, 2017 | 10:26 AM
Yes, I believe you are correct. This RPF1 is one of just a few that actually clear the front brakes
The 17x8 +35 is almost identical to the stock wheel (just 3mm further outboard). Running a 235 should be totally fine w/out a rear roll
Old Dec 15, 2017 | 12:54 PM
acidreian's Avatar
I have set of RPF1 in black on my 05 RS and they clear very aggressively when i get home i can give you the sizes i used and pictures if you want to give you an idea.
Old Dec 15, 2017 | 01:04 PM
sounds good! Thanks!
Old Dec 17, 2017 | 04:15 PM
acidreian's Avatar
Old Dec 17, 2017 | 07:32 PM
Wheels look good on the RS. Please post up your shots here in the RS Only Thread
https://www.evolutionm.net/forums/ev...ry-thread.html
Old Dec 18, 2017 | 09:18 PM
thank you for all the feedback! I’m thinking I’ll probably move to a 17 x 9.5 + .38 mm offset in the Rpf1’s with 255/40/17 tires. I saw someone running this set up and they did 20mm spacers up front. Hopefully that should work with no rolling involved.
Old Dec 19, 2017 | 08:50 AM
Jonno99's Avatar
I would be interested what minus says but i think because you are lowered you are going to need work
Old Dec 19, 2017 | 08:01 PM
Wanted EVO IX's Avatar
I run this setup and it works good. I did add 10mm spacers in the rear but rub from time to time. That setup I have doesn’t have rolled fenders but I’m thinking I might need to. It’s the best look in my opinion.
Old Feb 21, 2018 | 03:50 PM
SIM08U's Avatar
they're a nice wheel. but dam they're everywhere in my country lol
MODDICTION
EvoX 'For Sale' Wheels / Tires
95
Apr 26, 2018 06:50 AM
XTR Performance
Evo 'For Sale' Wheels / Tires
43
Mar 7, 2013 06:13 PM
Gruppe-S
56
Apr 18, 2012 04:44 PM
kingpoop
Sep 22, 2003 12:30 PM
