Rota grid drift ADVICE
Evo 9 standard brembo
right, after reading loads of threads etc..
i am ordering rota grid drift 18. 9.5j et30.
id like final advise on these. On if they will fit or not.. They come with falken 235/40/18 fitted on them.
I’d like the widest stance look. ideally I’d like none or minimal work done to the arches etc.
soo what are my options with spacers/arches/camber to avoid any rubbing? Or anything else I’ve missed.
thanks
thanks
thanks
thanks
You will need a tight rear roll for this to fit. If the tire was wider (i.e. 265ish), a rear fender pull, & bumper bolt relocation would be needed
Not sure about how they fit over the front Brembos ? Can you test fit them to determine the front fit?
Camber should be set at approx: Max -2 front / Max -1.8 rear (just a basic street range for aggressive driving)
They will fit fine!
I have the exact same spec wheels and tyres on my VI.
They do require 6mm spacers to avoid rubbing but your 9 won’t.
The 235 stretch on a 9.5 wheel is the limit according to Tyre manufacturers.
J88HNB
13
Feb 8, 2012 09:22 PM
Done
May 13, 2009 09:22 AM
WheelDude.com
419
Oct 11, 2008 12:45 PM
