Where to mount rear shock reservoirs?
I just got in my Feal 442 coilovers and noticed that the fronts have the reservoirs mounted to the shock yet the rears dont. For those of you who have something similar to what I have, where did you mount the rear reservoirs? They need to be somewhat easy to get to since the adjuster is on it. Just looking for some ideas. Thanks!
There was a recent thread on this in the MS section.
Here it is!
https://www.evolutionm.net/forums/mo...eservoirs.html
Id say if you have the length something like a rear strut bar would be a nice place to put em. Keep in mind you'll probably be cutting a hole in the trunk pan to get the canister through. I've still gotta figure out mine at some point.
Here it is!
Thanks for the link! I took a look through it and most of that is for the front resis though. Couple mentions to the rear.
Cutting a hole in the trunk.......... not a huge fan of doing that. I can if I have to but I would prefer not to. My car is not a track ***** just yet haha.
Was thinking about possibly mounting them under the car on the subframe? Kinda above the center of the sway bar.
How are yours mounted now?
Its not as simple as that sadly. Need to depressurize the system but after that run the risk of the shock oil leaking out as well as air entering the system. I looked into this lil over a month ago after picking up a set of AST5200s and was told its a nogo. Need to pull a vacuum on the system blah blah blah its a whole process.
I dont think they are going to be long enough to run them through the vents either. Probably need about 3ft of line to do that. I'll pull the trunk carpet out this weekend and start brain storming.
For those of you who did cut some massive holes in the trunk, what did you use for a grommet?
I am thinking once I cut the hole, I can cut a circle out of sheet metal that is bigger then the hole I cut in the body, drill a hole in the center for the hose to go through, cut that circle in half and then bolt those 2 pieces back in, if that makes any sense.
Apex Hunter (Jul 18, 2019)
You mean you arent a fan of my zip ties!? Man, I can add some duct tape if that would help haha.
I drive the car once a week to work and sometimes on the weekend. Never in the rain. I feel like they will be fine where they are.
Well I do have to say, it is stiffer now, mostly just on big bumps but it's not as bad as I thought. Time to get corner balanced and an alignment. Then start messing with the settings.
