Wrong bolts?
I guess it's easy to make arms if we can find the measurements for the bolt holes. And I guess a heim "end" with a ball joint is something already made and we just have to find the one that fits our uprights?
Please do! I'll be doing the same. I just got an email from Enjuku saying the Megan arms are also out of stock. Apparently there are no toe arms to be found in the U.S.
Toe arms see very little load. I can pull the alignment bolt out while the car is sitting on the ground. I can't imagine we'd need anything too robust. If Megan would work, anything should
I'm seriously about to throw on some ebay arms to hold me over. I think I'd rather do that than raise the ride height and/or reduce camber.
If anyone has a way to measure the taper on our toe arm ball joint, I can find some tie rod ends to match, then build the rest pretty easy. Sounds kinda fun, though I am having trouble finding the longer center section. I'm thinking I can look up where I got the aluminum part for my sway bar end links, then find the larger size.
I can measure whatever you need while on the car. I'm stuck on the ball joint, though. I think I have all the the other parts figured out. Basically a larger version of my end link, with a ball joint on one end
That's what I plan to use if the dimensions are the same. Or even a set from Rock Auto or something.
I won't have time to pull the car apart in order to measure the joint, for a few weeks.
Collecting all these pieces....I do kinda like how these things would look. And I always prefer to make my own.stuff..
I could always buy the ebay arms and measure those. They're only, like, $70.
but yeah.. I have a feeling the quality isn't *too far* off. My main concerns are the ball joint and corrosion resistance.They are coming from China, so will take a month to get here. According to HardRace, DME, Megain, etc.. the evo 8/9/10 all use the same arms. The chinese company lists these as Evo X arms.. but I'm gonna go ahead and order them anyway.
I would, but still get the measurements for ya and so I could tinker myself. The ebay ones don't quite look the same as the other brands, particularly the sphericals. But, If I can buy, measure, then use 'em until I make my own (in case of failure) then I figure "why not?"
I actually found a "local" shipper. I should have them by next Fri. I'll get the measurements to you, if you still need them.
Looks like about $260 to make my own, with the parts I want. A bit pricey, but at least I'll know they are quality. Plus I will be making them, which is always more funner.
Can you share a link to the ones you bought? Would love to see some pics when you get them!
They dont look GREAT..but I may have a track day scheduled for that Sat, so need something...
