Front fender clearance.
Old Aug 15, 2019 | 06:53 AM
DSMolition's Avatar
I keep reading about people pulling fenders but nobody really says how to do it. I need about 2 to 3 mm of clearance up front so it sits flush. Is there any tips or tricks on getting a little more room on the front fenders and moving them out a little bit without adding the spacer in the door jam?
Old Aug 15, 2019 | 07:12 AM
I think youre already on the only path we know of. The EvO Dave spacer kit.! Never seen anyone apply a pull to the front fender
Now, in the rear, the pull is the only option avail
Curious how low you are in the front. Im set at the following:
Fender to ground = Front 25.375" & Rear 25.000"
Just thinking that if youre lower than 25.3", you may want to consider adding a bit of ride height?
Old Aug 15, 2019 | 07:59 AM
DSMolition's Avatar
I would have to measure but im not super low. I have been slowly increasing the ride height and it might be my only option just figured I would see if there's any others doing anything different besides defender mod. That seems to only push the rear out?
Old Aug 15, 2019 | 09:45 AM
Some have tried rolling the fronts but being alum there is so much memory in that material that its hard to roll w/out distorting it.
Although extreme, some wider glass fenders might be in order?
Old Aug 16, 2019 | 12:40 PM
Name User's Avatar
I've uhhh done some very bad things
I'll take care of it later, but I'm hoping I don't need to go past Step 2:
Step 1: smaller spacers
Step 2: home depot
Step 3: seibon
Old Aug 16, 2019 | 12:54 PM
Step 2: home depot
Step 3: seibon
Are you noting the poke or is there something else there? What did ya do?
Old Aug 16, 2019 | 01:11 PM
Name User's Avatar
Yeah just the poke, it's a whole lotta poke. 10mm less spacer should pretty much fix it, and then maybe a little bit of the fender mod.
ChrisCrossCrash
Midwest Region
Mar 24, 2018 01:39 PM
reggiesd
North Texas Evo Club (NTEC)
Mar 5, 2010 01:50 PM
booster9
Jan 30, 2009 01:46 PM
EvoIXMR
15
Aug 6, 2008 04:22 PM
