25mm sway bar
Hey,
I just got a new 25 mm sway bar (Road and Race) for my evo and was wondering if new endlinks are needed, and how much of a difference new (stronger) ones would make. Does anyone out there have a larger sway bar without new endlinks? How does the car ride and have you had any problems?
Thanks,
Mike
Thanks,
Mike
I'm going to be purchasing a new larger swaybar as well, and I would definitely get new endlinks.
Put it this way... you are putting in a stiffer bar and thinking of keeping endlinks that are as thin as a pencil?
I guess you could keep them, but if you are going for increased stiffness, take all the play out of the setup.
All of this, of course, is just my humble $.02.
The stock end links are fine. I use Works 24mm 3 way adjustabale rear sway bar. Before I did the my front sway bar mod,I had the rear one set in the last hole I could lift the tires off the gound. The stock end links do work.
I kept the stock endlinks as well (25mm Progress bar here). Car rides fine, even with the Tanabe GF210's. I have 2 autoxes this weekend, so I can speak better of the performance then.
