Tire wear
Old Jul 24, 2021 | 09:01 AM
Jestersplay's Avatar
Tire wear
Ok have a few questions here. The inside of my tires are wearing bad. Fronts only. I had a alignment done with install of brand new tires. 12k miles front inside tires, both left and right are down to the threads. I had -2° of camber put on all 4 corners.
My suspension mods if itll help
FA500s 9k front 11k rear swift spring
whiteline roll center stop kit
Energy suspension complete bushing kit
My first question is. Is there a left and right on fortune auto coilovers? I saw no markings. If so this may be the cause of tire wear.
Second question is. I put energy suspension bushing kit in the control arms. The large one isn't spherical like. Would this cause the tire wear?
Car drives perfectly straight so alignment shouldn't be the issue (unless one or 2 of my questions is culprit)
Any advice or information is much appreciated and thanks in advance.
Old Jul 24, 2021 | 02:49 PM
Im on FA's as well. Mine are more than a few years old & have no brake line attachment so mine are not handed.
What are your toe settings? Toe can certainly cause inside tire wear.
Factory toe specs are: 0 ± 0.08 (inches)
Old Jul 24, 2021 | 03:43 PM
Biggiesacks's Avatar
How soft are your tires? How many times did you rotate them? How much tire pressure are running? Urethane is a downgrade over factory sphericals, you could be getting more dynamic toe/camber from deflection under loading.
Old Jul 24, 2021 | 04:05 PM
RazorLab's Avatar
Crap alignment. Too much toe. Run zero toe if you are concerned about that type of tire wear.
Old Jul 25, 2021 | 03:29 PM
I can't remember what the toe was set to. I only remember specifying -2° camber.
Old Jul 25, 2021 | 03:32 PM
tires are federal 595rsrr. Only rotated them once just recently. Car sits for winters. I originally went to rotate around 6k miles but thats when I noticed the wear. I didn't wanna wear the back set. I need new tires regardless but wanna figure out the cause before hand
Old Jul 25, 2021 | 04:20 PM
RazorLab's Avatar
99.9% toe.
Old Jul 26, 2021 | 07:38 AM
With the evo AWD system you are replacing all 4 tires regardless (unless you like replacing expensive drivetrain components) so go ahead and rotate in the future, the stickier the tire the more aggressive you need to be about rotating them.
Like Razorlab said, you need to go get your alignment checked and dial out any excessive toe. 0 toe on all 4 is what is most commonly recommended for our cars, and they don't seem to have any stability issues (that I have experienced, or that anyone else has reported) at those setting. If it turns out your toe is already pretty conservative, you could start diving down the suspension rabbit hole.
Risky Guy
Apr 23, 2014 03:17 PM
deadstockkpomp
17
May 3, 2013 11:11 AM
B4Boost
Nov 17, 2012 06:02 AM
black95tt
Sep 10, 2009 09:24 AM
Gooseman396
Mar 6, 2009 11:31 AM
