OEM Struts/Shock Mount Upgrades and Install DIY
Old Oct 6, 2021 | 11:24 AM
Evo_Matt's Avatar
Hi everyone,
I did a bunch of searching on here and with the Googles and I didn’t find much on this.
I have a set of Blisteins with Swift Spec R springs and I want to install camber plates up front to get close to -3 degrees up front. I found the Works front and rear mounts, but it isn’t super clear that they will work with OEM style front and rear struts/shocks?
For install these just go above the upper spring mount on the front and top of the spring in the rear? Directions available online (Tein) aren’t awesome.
Thanks!
Old Oct 8, 2021 | 10:48 AM
ViciousLSD's Avatar
hmm why do you need that much camber with a stock-ish suspension?
Old Oct 8, 2021 | 01:44 PM
Dallas J's Avatar
Veteran: Army
Originally Posted by Evo_Matt
Hi everyone,
Thanks!
Way back in the day I ran a set of tein top hats on Bilstein's and gtworx spring. Worked just fine. Been too long to remember how its installed but likely required a spring compressor because I think only the top nut is used to hold the assembly together.
Old Oct 10, 2021 | 09:27 AM
Evo_Matt's Avatar
I want to use the car mostly for track days and it seems like a lot of the setup threads recommend up to -3 degrees camber. I figured while it was apart I could throw some camber plates in and when I’m at the track I’d have more adjustment then I probably need.
Old Oct 10, 2021 | 09:32 AM
Evo_Matt's Avatar
Thanks! A quick search of the Tein site does show one’s that work with OEM style springs; they must have discontinued them.
Maybe it’s time to buy a coilover setup…
Raceghost
Jul 3, 2009 12:49 AM
jojipoji
May 30, 2008 11:31 PM
MRinChrist
Aug 10, 2007 10:15 AM
