Sway Bar Bushing Squeaking - What Grease?
Old Apr 30, 2004 | 04:02 PM
freedom's Avatar
One of my rear sway bar bushing is making really bad squeaking sounds. I have never had a car with rubber bushings make noise before. I assume the solution is to use grease.
What grease do you recommend using?
Old Apr 30, 2004 | 04:07 PM
bolsen's Avatar
I've often wondered the same. I'd say just a standard mobil grease or whatever. Tho not too much cause you don't want it to collect dirt
Old May 1, 2004 | 02:15 PM
CarFanatic's Avatar
use teflon tape, instead. No squeaks.
Old May 1, 2004 | 02:21 PM
sr20det91's Avatar
or a lithium based grease works well also, you cant beat teflon tape though.
Old May 1, 2004 | 02:51 PM
freedom's Avatar
And likely to hold up where I'm guessing the grease just defers the problem for a few months.....
Old May 1, 2004 | 03:33 PM
CarFanatic's Avatar
yea, its the best bet. Just wrap the bar were the bushings sit and wala. no more squeaks.
Old May 1, 2004 | 05:22 PM
freedom's Avatar
Talking
Exactly what I did. Works - no more squeaks!
Old May 1, 2004 | 05:31 PM
hel_if_ino's Avatar
well, if it happens again, you need to go with lithium grease, especially if you have urethane bushings.. depending on who you bought it from they should have supplied you with a small amount of lithium grease for this very reason..
koolzero
Nov 20, 2015 04:46 PM
Peter Gallup
Sep 12, 2011 12:42 PM
bowlofturtle
Dec 21, 2010 10:58 AM
davemiro
Lancer Troubleshooting
20
Oct 14, 2009 10:20 AM
mcgarvey
Dec 1, 2007 12:55 PM
