AutoX wheel combo... Neal help..
Old Jun 10, 2004 | 12:09 PM
Kyperion's Avatar
Neal,
I am looking for info on your lightest 17x8.5 inch rims with 255 r compound tires. I am looking for the lightest combo I can go with, and I am not sure if that is kosei TS, or something else I have not though of. Looks are irrelevant for this, but price is a consideration. Any advice would be greatly appreciated.
Old Jun 10, 2004 | 12:12 PM
Neal@tirerack's Avatar
The lightest wheels I carry in 17X8.5 are the SSR Comps, which weigh in at 15.5 lbs. The Kosei wheels only come in 17x8 which wont work with a 255 width tire.
Old Jun 10, 2004 | 12:14 PM
Kyperion's Avatar
thanks
I am trying to figure out how to get these in place for the end of the season
Old Jun 10, 2004 | 12:18 PM
I currenlty have them in stock, but there not the lesser priced of the bunch... It might be best to run a 17x8 and a 245 to save a bit of $.. not a really big difference between 255's and 245's. More people have had better luck (especially with fitment) using a 245.
Old Jun 10, 2004 | 12:23 PM
Kyperion's Avatar
do you guys have nay rims that will allow for 276 Kuhmo V700's. I know thaat there are people running 275's but not sure on what rim.
Old Jun 10, 2004 | 12:26 PM
you would need a 9 or 9.5" wheel to accomidate a 275, and I dont have anything that wide in 17" for the EVO
Old Jun 10, 2004 | 12:32 PM
Kyperion's Avatar
ok
I am going ot have to find out what rims they are using. I would like to run 275 Hoosier AS304's, but have to find rims that will fit them
Old Jun 10, 2004 | 02:58 PM
bullfrg's Avatar
I remember a post about SVT Cobra rims that were 17x9 and fit the Evo. I think they were cheap too ($150 per wheel IIRC). That should fit the bigger tires you want to run.
Here is the link:
https://www.evolutionm.net/forums/sh...ighlight=Cobra
Old Jun 10, 2004 | 03:04 PM
The Cobra wheel is 8mm differ in offset and 3.5mm differ in center bore. Might bolt up, but theres a good chance its going to vibrate.
Old Jun 13, 2004 | 09:06 AM
Kyperion's Avatar
that and they are REALLY HEAVY compared to a kosei or other light weight race rim.
Old Jun 15, 2004 | 12:01 AM
jbrennen's Avatar
I believe that Trbo Dad is running 275 Kumho Victoracers on 17x9 rims. IIRC, his wheels are 5Zigen FN01R-C. I can say that I am running the 17x9 FN01R-C (35mm offset) with 245 Hoosiers and there is no problem -- I don't think I'm rubbing anywhere even under hard cornering. At least the tires don't show any signs of rubbing.
It's a good bet that the 275 Hoosier is a wider tire than the 275 Victoracer. If you put 275 Hoosiers on the Evo, you can expect that you will have some "issues" to solve.
