Bizarre alignment at Firestone?
Old Jun 10, 2004 | 03:44 PM
zstryder's Avatar
I went to Firestone the other day and got their lifetime alignment package for $130. Not a bad price, I thought. I was in a hurry so I didn't get to see the thing until today, but it looks like they didn't completely get everything on spec.
I believe these are the factory alignment specs:
Front:
Toe-in mm (in.): 0 +/- 2 ( 0 +/- 0.08)
Camber (Selectable from 2 options): -1deg +/- 30' or -2deg +/- 30' (left/right deviation within 30')
Caster: 3deg55' +/- 30' (left/right devitation within 30')
Rear:
Toe-in mm (in.): 3 +/- 2 (0.12 +/- 0.07)
Camber: -1deg +/- 30' (difference between right and left within 30')
This is what they did:
What's with the front camber? Or am I reading this thing wrong?
Also, they said there was no way to set the front caster? I don't know much about how alignment works (got a FAQ somewhere?) so if anyone knows anything and can chip in, I would greatly appreciate it.
Old Jun 10, 2004 | 03:49 PM
jj_008's Avatar
It looks like they didn't know the front camber was adjustable so they didn't due it.
Old Jun 10, 2004 | 05:38 PM
mhgsx's Avatar
Are you lowered?
Negative 3* is a bit much for the street.
Old Jun 10, 2004 | 05:53 PM
zstryder's Avatar
Everything is stock. I thought the front camber could only be selectable between -1 and -2?
Old Jun 11, 2004 | 07:54 AM
mhgsx's Avatar
Actually, looking again at the pictures, it looks like they don't even have a reading for the front camber. If nothing was touched, then your camber bolts are set up in the -1* setting.
Everything else looks OK. Since you've dialed out quite a bit of negative camber off the rear, be careful lifting the throttle when going around fast turns. Your setup should rotate nicely w/ lift throttle.
Also, how much gas did you have when you had the car aligned?
Old Jun 11, 2004 | 09:32 AM
zstryder's Avatar
The tank was about half full - the guy also had the car running (engine on) when he did the alignment. Is there a special way to do the caster? The guy said the car didn't have a way of setting the caster.
Old Jun 11, 2004 | 09:40 AM
992gnt's Avatar
You can't adjust caster without bending the control arms or buying adjustable control arms. Something is messed up with the front camber though - it looks like they didn't have the machine set up right. You won't get 3* of front camber without camber plates.
Old Jun 11, 2004 | 03:45 PM
dv8_evo's Avatar
in the original post, zstryder asked if there was a FAQs reguarding alignments, caster and camber... anyone know a good faq? ive been wonderineg too
MikeColangelo
Northwest Region
May 27, 2009 11:19 PM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
jesterEVO
45
May 15, 2006 07:26 AM
Blue_by_u
11
Sep 24, 2004 09:56 PM
Daveyd
Jul 21, 2003 10:07 AM
