Eibachs and alignment
Old Sep 9, 2004 | 01:45 PM
EVONation's Avatar
Are there any pictures???? The eibachs seem great but I just can't make up my mind...
Old Sep 12, 2004 | 02:10 PM
ammitsuevo's Avatar
just got these as well- dont have them on yet though so I hope I chose right
Old Sep 12, 2004 | 03:13 PM
VTECH8TR's Avatar
Originally Posted by 6one9EVO
would it be best to get your alignment adjusted and getting your camber corrected after you put these springs on?
If you dont want to buy tires any time soon. I suggest you get it aligned right away.
Old Jan 8, 2005 | 10:46 AM
oguratevo's Avatar
Originally Posted by hotrod2448
I recently installed the Eibach Pro-kit springs in my Evo. My only gripe is that they can no longer get the rear toe back to spec. Right now I've got about a degree of toe out total across the rear. Has anyone else had this problem with these springs? Does anyone know of an adjustable toe link for the Evo? When I put the Tein High Techs on my other Evo I didn't have this problem but, they didn't lower the car nearly as much as the Eibachs in the rear.
Please only respond if you have helpful info not the "way to ruin a great suspension" or "you should've got coilovers" B.S.
Thanks
Installed my pro-kit on my MR, only adjusted made were the front camber, the rear seems ok according to the alignment results.
Old Jan 8, 2005 | 10:52 AM
BJai02's Avatar
EVO's alignment is very adjustable. If your mechanic can't get it to spec, go find another alignment shop. I had H&R springs and now Cusco Zero 2R's, and I had no problem getting it aligned to spec.
hispanicpanic
12
Jul 5, 2015 06:50 PM
Kento240
15
May 2, 2012 12:42 PM
GOKOU
20
Apr 22, 2005 11:34 AM
EVO8LTW
37
Sep 27, 2004 09:23 AM
lancerslc
Jun 14, 2003 04:07 AM
