Do Prodrive GC010E wheels fit the Evo?
From: Why do they always call the Evo the Dark Side?
17x7.5, offset is +38. One of the Subie folks is selling theirs and I'm just wondering if they'd fit an Evo - they are mighty hot.
Thanks,
john
Thanks,
john
No, that particular size won't fit. They will scrub the calipers, and subarus don't usually carry a 5x114.3 bolt pattern. But Prodrive does offer fitments for the Evo 8 is these wheels. Check prodrive-usa.com.
Chris
Chris
yes, prodrive make wheels for the EVO but the ones the subie guy is selling will not fit due to a different bolt pattern and offset:
http://www.z1auto.com/submodel.asp?model=evo&cat=wheels
Even if they are for a 05. The offset for the EVO and the STi are different though. So you may want to make sure you have all the specs so you can see if they are the wheel for you.
18” x 8.5” GC-010 Wheel:
Colors: British Black, Metallic Silver
Fitment Specs:
Bolt Pattern: 5 X 114.3mm
Offset: +22mm
Weight: 17.75 lbs
That is the wheel you want.
Ben
Fitment Specs:
Offset: +22mm
Weight: 17.75 lbs
Ben
Originally Posted by value
Prodrive Japan says to run a +34 offset both 17 or 18 inch. Prodrive US says +22 with only the 18 inch listed ??
xpehbam
Jun 2, 2009 03:18 PM
petey pab
12
Feb 8, 2005 12:14 PM
