Cusco sway bar torque spec
Old Aug 27, 2004 | 06:19 AM
mongol311's Avatar
Exclamation Cusco sway bar torque spec
Probably a stupid question, but I can't find the answer anywhere. Just bought the cusco 23mm rear sway bar, and was wondering what spec it should be torqued to.
Old Aug 27, 2004 | 06:48 AM
mayhem's Avatar
According to STOCK specs the bolts at the ends of the bar are 29 +/-3 ft*lbs
The two bolts that go on the clamps that are parallel with the ground are also 29 ft*lbs
The single bolt that is perpendicular to the ground and goes on the clamps is 18 +/-3 ft*lbs
Hope this helps.
Old Aug 27, 2004 | 08:46 AM
mongol311's Avatar
Thanks a ton dude. By the way, does anyone know where I could "find" a copy of the mitsubishi evo service manual?
Old Aug 27, 2004 | 09:39 AM
spyderx's Avatar
machv.com
xmel012
Jun 6, 2017 12:13 PM
nickleo373
Mar 23, 2016 10:35 AM
beastly_evoX
Dec 31, 2015 04:33 PM
Cyrax91
Mar 26, 2012 11:09 PM
