Official HKS coilover review thread
Old Sep 17, 2004 | 01:53 PM
Karash's Avatar
That rear camber seems excessive, especially if you want to rotate the car easier. The front is fine, but I would just try a 0 camber in the back and see how your front bites then. Also, are you running Yoko's?
Great write up!
chapter8's Avatar
damn gruppe-s has them in stock......and HKS USA has them too
Old Sep 17, 2004 | 01:56 PM
chapter8's Avatar
Great write up!
Im runnin falken azenis
You think I should go with less camber in the rear...it wall cuase more oversteer?
Old Oct 23, 2004 | 03:00 AM
ADVAN's Avatar
can i install hypermax II to my evo III coz my brother in japan send me 1, its from Up-Garage, they specificaly said it will fit evoII-VII
Old Nov 1, 2004 | 08:57 PM
eclipsegs2k1's Avatar
My Hipermax II's finally came in today! It could be a few days before I have them installed, but wow, it took awhile, but they seem to be really nice... too bad all the instructions are in japanese... hopefully the guy i take it to will already pretty much know what to do. I will post my review in this same thread when I finally get them on the car!
Old Nov 2, 2004 | 05:54 AM
Aluma's Avatar
toe out in front gives good initial turn in but tends to push at the end of the turn(plus make s the car twitchy.)...less toe out or a little toe in gives less turn in but you get steering back in the end of the turn although that would make the car wander a bit on the straights.
Old Nov 2, 2004 | 05:59 AM
chapter8's Avatar
hot
Old Nov 2, 2004 | 09:31 AM
bigyellowevo's Avatar
I have the hypermax 2. They are very easy to install, took me all of 1.5 hours with the proper tools. Here's a couple of pics.
Ok, this picture has nothing to do with suspension, just wanted to showoff my new fmic, lol.
Old Nov 8, 2004 | 09:18 AM
ok guys, I need some help... I'm getting the Hipermax II's installed on Wednesday. My question is where should I set the ride height... I want it as close to stock height as possible because I don't want to scratch and scuff up my front bumper. Is it ok to set them up to full height in the front and back? If I do set them up that high, it won't be higher than stock right, or will it?
Old Nov 8, 2004 | 01:01 PM
bump for my question
Old Nov 9, 2004 | 07:20 AM
no one???
Old Nov 9, 2004 | 06:41 PM
Z1 Performance's Avatar
there should be recommended settings in the instructions...usually its a relatively mild 20mm drop
Old Sep 17, 2007 | 07:04 AM
timmiii's Avatar
OP, did you ever get that roll issue fixed?
Old Sep 19, 2007 | 09:44 AM
volkskid's Avatar
when setting the damping on the hipermax, do you guys click max to stiff and reduce from there? i was told if you click max to soft, you run the risk of the damping rod or something going out of place?
Old Sep 26, 2007 | 08:17 AM
timmiii's Avatar
bump
DSG Performance
EvoX 'For Sale' Suspension / Brakes / Handling
11
Nov 27, 2015 09:28 AM
jimm
Aug 21, 2015 08:32 AM
silverIXMR
15
Jun 7, 2010 09:02 PM
DrivenConcepts
Evo 'For Sale' Suspension / Brakes / Handling
47
Aug 7, 2006 08:30 PM
Vivid Racing
May 13, 2005 09:45 AM
