Anyone have the JDM double-din headunit kit? Metra kit sucks!
Old Jul 15, 2008 | 08:59 PM
bluewaterDEMON's Avatar
Just wondering if anyone has the JDM install kit? My Metra install kit has too many gaps and doesn't sit flush, and it makes my interior look more cheap than it already is! If anyone has the JDM kit, post up some pics! Thanks.
Old Jul 15, 2008 | 11:43 PM
EvolvedVIII's Avatar
Mine is scheduled to arrive around the 25th of July. I'll post pics once it's it. I can't wait to get rid of this Metra piece of junk!
Old Jul 16, 2008 | 08:31 PM
malves85's Avatar
Why are you using the JDM version as opposed to the US?
Im going to be getting the pioneer avic-f nav screen and was planning on getting the US double din kit. Is the JDM better for any reason?
Old Jul 16, 2008 | 09:30 PM
duc996's Avatar
metra kit
I have the same opinion about the dash kit....mine warped being out in the sun. Could someone post a link to the JDM dash kit? Is it the double din? Thanks
Old Jul 16, 2008 | 11:31 PM
JDM one is recessed and made specifically to accommodate aftermarket double din head-units:
Meanwhile, the USDM one is made specifically to accommodate the OEM MMCS Navigation system which is much wider than standard double-din:
Old Jul 16, 2008 | 11:32 PM
BTW the JDM one can be purchased through www.japanparts.com
Old Jul 17, 2008 | 06:46 AM
Does anyone know if the JDM dash kit fits with no problem, even though its right-hand drive? The shape of the kit looks like it wouldn't really be a problem, but I didn't know if it was direct pop-in or if something needed to be modified?
I'm probably going to order the JDM kit from japanparts.com because my ****ty metra kit is pissing me off. The double-din headunit is too heavy for the kit, because metra had to design it so the headunit's weight was all on the plastic. And the fitment is horrible! (Yes I installed it 100% correct).
Hopefully the JDM kit allows the headunit to be mounted to brackets inside the dash, and than the faceplate pops over top of it. That would be perfect!
Old Jul 17, 2008 | 06:52 AM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Honestly I think you'll be fine. The system faces forward with no slight angles facing the driver (LHD or RHD)...which some systems back in the day used to. It should be a direct fit. Japanparts may also mention if its specific or not......
Old Jul 18, 2008 | 04:57 AM
Well, mine should be in early next week. I'll let you guys know then.
Old Jul 18, 2008 | 09:34 AM
bmx's Avatar
bmx
the JDM kit will definately fit because the Metra kit fits my JDM GSR. I have the JDM 2 din kit lying around thou....
Old Jul 18, 2008 | 09:44 AM
is there a reason you used the metra instead of the JDM one?
Old Jul 18, 2008 | 11:48 AM
x2. Please explain! I'm not sure what advantage the metra kit has over the JDM kit.
Old Jul 18, 2008 | 02:45 PM
Mzderrick04's Avatar
I have the metra kit and it fits and works fine...
Old Jul 18, 2008 | 09:11 PM
You're a lucky one. Most of them fit like crap.
Old Jul 19, 2008 | 12:32 AM
salukidude's Avatar
Here is my aftermarket double din in the USDM kit. Looks like shiat. I'm not certain the Metra kit will be that much better. Is JDM the way to go?
