Turbotrix Evo X 376whp/336ft-lbs
Old Feb 11, 2009 | 08:27 PM
TurbotrixRacing's Avatar
We put our Evo X back on the dyno today and we were amazed by the results. The last time Mark tuned the car it made 338whp/357ft-lbs @25psi. We just built a custom 3" o2 housing and cold air intake to the car. The car made 376whp/336ft-lbs @23psi. We ran out of fuel so we couldn't turn the boost up anymore. With the new setup the car hits 23psi and falls to 21psi by redline. Tomorrow we will be trying out a new set of injectors and then installing some Kelford stage 1 cams. Here are some pics of the cold air intake and the dyno sheet. The cold air intake is all one piece and has NO silicone bends.
Keith
Dynosheet:
Old Feb 11, 2009 | 08:50 PM
Clark_Kent's Avatar
Thanks for the update. I was wondering what had happened to your project X. Also, I am very interested to see the results of the Kelford cams.
Old Feb 12, 2009 | 07:59 AM
CatalystGod's Avatar
What's the reason for the lower torque?
Old Feb 12, 2009 | 08:15 AM
Guerillah's Avatar
low boost.
Old Feb 12, 2009 | 08:17 AM
DDATuned's Avatar
Keith , Do you make cold air intakes for the evo 8 ?
Old Feb 12, 2009 | 08:50 AM
No, but I can make one.
Keith
Old Feb 12, 2009 | 08:51 AM
Originally Posted by Guerillah
low boost.
You are correct.
Keith
Old Feb 12, 2009 | 09:24 AM
Guerillah's Avatar
Make sure to post up results of the kelfords! I havent seen any cam results for them, only cosworth.
Old Feb 12, 2009 | 04:31 PM
Tunerhead's Avatar
Nice results man!
Old Feb 12, 2009 | 06:23 PM
boostin20's Avatar
How is the maf mounted sideways not screwing up readings? The agp cai is mounted the same way and a lot of people are getting pissed because it's causing tuning problems. Plus, why would you set the bov on the top ic pipe and not near the throttle body coming off the lower ic pipe?
Old Feb 12, 2009 | 08:51 PM
REVOlution86's Avatar
plus 1 for what he said^ i had tunning problems cause of the maf in that position
Old Feb 12, 2009 | 09:47 PM
dustin03's Avatar
What did you use to tune the car?
Old Feb 13, 2009 | 05:31 AM
Mad_SB's Avatar
The softest X I have seen to date was using the AGP intake, Leaned him out to 12:1 with no tuning at all. After tuning I was still weak sauce. The X uses a map airflow calc along with maf airflow calc, if the two get very far apart it will start flopping between map load and maf load and makes it very difficult to tune. The X in question is a good 20-30whp down on other cars with the same mods.
I think the issue with the agp intake is the diameter of the maf pipe is too large.
T.T. what the is the pipe diameter where the maf mounts in comparison to the stock maf housing?
Also, the maf is in the same orientation as the stock setup, just in a different location and different pipe.
Old Feb 13, 2009 | 06:02 AM
woodyqb's Avatar
It seems like it would be beneficial to put the bov off the licp into the intake, that way at least you are dumping slightly cooled air back into the intake rather than hot air. This setup might cause a problem similar to what people were seeing when the ac fan kicked on and threw hot air into the intake causing stumbling problems, hence all the air filter shields like buschurs. I think that setup would be bad *** if the bov was just above the maf, or if you could slide the maf down a bit further and put the bov where the maf is now
Old Feb 13, 2009 | 06:36 AM
boostin20's Avatar
The whole point of a bov is to relieve pressure from the engine while shifting. The ideal bov placement is as close to the throttle body as possible, as to be the farthest away from the turbo to allow turbo to stay spooled a little (split sec) longer. The recirc comes into play to aid turbo staying spooled. The only thing I can guess after thinking about it for a couple hours is they want the shortest route between bov to recirc point in the intake in hope that while pressure is lost instantly, the recirc has an extremely short path to aid in turbo staying spooled.<-- just my theory, I hope turbotrix can chime in on why they chose that placement.
