EVO MR (almost stock) Flashed
Old Mar 27, 2009 | 04:34 AM
chueu's Avatar
Talking EVO MR (almost stock) Flashed
Just got my car tuned/Flashed
Modifications:
HKS Racing Suction Reloaded, HKS EVC for Evo X
Fuel Type: RON98 (i think equivalent to 92oct)
Environment Temp: 29degC (temp whole year round, tropical country)
Evo Type: SST, Supposedly AUSDM (i have heated seats, headlight washer, etc) but tuner said the ECU was UK version
Flash Type: ECUTEK
Tuner: Ohura Shunpei (HKS Master Tuner)
Dyno Type: DynoDynamics Possum Bourne Edition (apparently reads low)
Baseline before tune: 285 HP / 291.30lb/ft @1.5bar
After Tuning: 327.9HP / 331.12lb/ft @ 1.5bar
Am quite happy with the results, all i can say is why did the EVO not come like this from factory. Tuner told me fair amount of resistance and 350hp was easily achievable with exhaust. Boost was set conservatively at 1.5 tapering to about 1.2.
Comments Pls.
HP / TORQUE
HP / BOOST
Old Mar 27, 2009 | 04:35 AM
chueu's Avatar
Vid:
http://www.youtube.com/watch?v=gqG3cNu3OrE
Old Mar 27, 2009 | 06:01 AM
ugakirk's Avatar
Im interested! Post Vid!
Old Mar 27, 2009 | 06:12 AM
chueu's Avatar
posted, edited above
Old Mar 27, 2009 | 08:53 AM
Mad_SB's Avatar
looks like the tuner did not touch the mivec maps as your not spooling any sooner than stock after the tune.
Old Mar 27, 2009 | 09:51 AM
chueu's Avatar
He told me that he did.. maybe in the Upper RPM'S?
Old Mar 27, 2009 | 10:07 AM
STi2EvoX's Avatar
Modifications: HKS Racing Suction Reloaded, HKS EVC for Evo X
Normally you are right, dyno dynamics read low. That one, on the other hand, does not. It has been calibrated to read like a dyno jet apparently, because a stock X with an intake will dyno around 230 on most dyno dynamics. Add in the boost controller, and you'll pick up a little more, but no where even close to your baselin of 285. Not trying to knock your setup or anything, but if you go over to a dyno jet thinking that you made 327 on a low reading dyno and are expecting to see 365, you're in for a rotten surprise.
Old Mar 27, 2009 | 10:24 AM
Noize's Avatar
EvoM Administrator
Originally Posted by STi2EvoX
Normally you are right, dyno dynamics read low. That one, on the other hand, does not. It has been calibrated to read like a dyno jet apparently, because a stock X with an intake will dyno around 230 on most dyno dynamics. Not trying to knock your setup or anything, but if you go over to a dyno jet thinking that you made 327 on a low reading dyno and are expecting to see 365, you're in for a rotten surprise.
Just kidding, buddy!
No, its not recalibrated. It is, however, in shootout mode, look at the screen for proof. Those numbers are an estimated crank HP, and an option in the software if you want to run it that way. Shootout mode reads a lot higher than a Dynojet. In standard mode, that 327whp would show about 255whp. Not bad for an SST.
chueu's Avatar
That's flywheel tho... So i guess 285 is fair?
285 shud be round about 230WHP
Old Mar 27, 2009 | 10:25 AM
willitas34's Avatar
^^^Unfortunately i think he is right
Most EVO X's on a low reading dyno (Mustang, Dynodynamics) that i have seen with a tune around bay area are doing about 280-290whp at the most
Old Mar 27, 2009 | 10:30 AM
Mad_SB's Avatar
Shoot out mode dude, in the states we use it to get a fairly accurate crank hp number. Other area's they have a standardized setup and all try to use shootout mode to minimize correction factor usage. I think the dyno has to be certified by dynodynamics as part of the program, they don't do that here much.
chueu's Avatar
Now i'm really confused...
Coz the 327hp is flywheel.. not wheel....
And lotsa people have been telling me this thing reads damm low
EDIT: Mad clarified.. And yes DynoDynamics has certified this dyno
Old Mar 27, 2009 | 10:34 AM
Noize's Avatar
EvoM Administrator
Shootout is estimated flywheel, not wheel HP. I've got a lot of hours staring at those screens. Suffice to say, your car is fine, its making what it should. We rarely display Shootout in the US, so I was explaining to those who were confused.
Old Mar 27, 2009 | 10:36 AM
sohcpunk's Avatar
Eh, the SST aren't gaining as much as a GSR from a tune.
Old Mar 27, 2009 | 10:38 AM
chueu's Avatar
Haha.. thanks Noize...
Well numbers are just numbers... what figure a dyno reads doesnt really matter.. Just to get a baseline and improve on it anyhows...
But the Butt Dyno is telling me that this car is crazy now... am saving for the full TB Exhaust... will post again when i get it, prolly in a couple of months
