363 hp 372 ft/lb, cobb ap, e85
Old Dec 22, 2009 | 09:58 PM
lowkey's Avatar
Registered User
Blue Line, COBB E85 Off the Shelf map: 358 HP, 357 FT/LB
Red Line, COBB Pro Tune: 363 HP, 372 FT/LB, 26.5 PSI
Mods:
COBB AccessPort
DW800CC Injectors
Walbro 255 lph Fuel Pump (with green relay and Blaqops adapter)
New (Stock) Airfilter
AMS FMIC
AMS UICP
AMS Downpipe
COBB HFC
Magnaflow CB
E85
Graph below shows the following:
Bottom lines: Stage 2 OTS + AMS DP + COBB HFC + Magnaflow CB: 320 hp, 331 ft/lb
Middle lines: Stage 2 E85 OTS + AMS FMIC + AMS UICP: 358 hp, 357 ft/lb
Top lines: + ProTune: 363 hp, 372 ft/lb
Old Dec 22, 2009 | 10:02 PM
Clark_Kent's Avatar
Where's the graph?
Old Dec 23, 2009 | 11:35 AM
lowkey's Avatar
Registered User
Originally Posted by Clark_Kent
Where's the graph?
Graph displays fine for me. You can't see it?
Old Dec 23, 2009 | 11:51 AM
Clark_Kent's Avatar
I can now. Good results. How much power are you up over stock?
Old Dec 23, 2009 | 12:13 PM
BigT's Avatar
Looks real good! But, couldn't you turn up the boost a little bit more on e85?
Old Dec 23, 2009 | 12:16 PM
mlomker's Avatar
I'm assuming these are Dynojet-like numbers. My tuner had told me that the DW800's max around 320 on his DD whereas with the 1000's you run out of single Walbro first.
E85 on the stock turbo really transforms the car, though...the torque is addictive.
Old Dec 23, 2009 | 12:25 PM
Clark_Kent's Avatar
I bet. Too bad it's not readily available in my local area or I would have been all over it long ago. I probably won't even need a turbo upgrade if I can run E85 all the time.
Old Dec 23, 2009 | 02:10 PM
mlomker's Avatar
Famous last words, then you see a Dom2 running E85 with those gorgeous curves. It's the clutch upgrade that is holding me back--the next step is very spendy.
Old Dec 23, 2009 | 02:34 PM
lowkey's Avatar
Registered User
Over stock I don't know. But on this same dyno with AP Stg2 + 93 + AMS DP + COBB HFC + Magnaflow CB it was 316 hp.
In other words the same setup as above plus E85, FMIC, UICP = 47 additional hp
Old Dec 23, 2009 | 02:38 PM
lowkey's Avatar
Registered User
Nope, tried... the turbo just could not handle it.
Old Dec 23, 2009 | 02:40 PM
lowkey's Avatar
Registered User
This is a Mustang Dyno. Correction factor based on built in weather correction black box was about 1, i.e. no correction.
Old Dec 23, 2009 | 02:44 PM
BigT's Avatar
hm.... my car on 28psi made more than 26, in regards to torque, on 93 octane,
Old Dec 23, 2009 | 02:45 PM
goofygrin's Avatar
hmm... wonder why you couldn't get that 412tq that Chris is getting?
Lots more power than you had a year ago when we rolled fenders
Old Dec 24, 2009 | 08:55 AM
lowkey's Avatar
Registered User
Simple, Chris' car was able to sustain more boost.
Old Dec 24, 2009 | 12:08 PM
RB185AFM's Avatar
+1
I have buy a stupid clutch next. But want turbo so bad.
