Mustang vs DynoJet comparo
Great thread! Its funny how some tuners will post up dynographs of say 350whp and some people think their tune or mods are the $hit yet in reality their gains are the same or less than a tuner who posts up a graph showing a peak of 300whp. You have to first dyno the car bone stock and get a baseline before anything, otherwise you might be severely disappointed when your high whp car isn't performing like you think it should be. Also, I feel a lot of people look over the power under the curve and just look at the peak #'s. Big mistake.
So how useful is the 'vehicle' coastdown test calibration for the parasitic losses vs the default curves? The default MD curves were only performed to 80mph when we received ours.
*edit*
Now that I've re-read your post I think I know what you are asking, but the vehicle coastdown is different then dyno coastdown for parasitic check. I was talking about dyno coastdown. If you want to do vehicle the best way is to do it on flat ground in neutral. If you want to get the times and give me weight of your car I have a spreadsheet that gives me ABC coeff. and hp@50. This is more accurate then using frontal area and guessing rolling resistance ect. which is how they list vehicles in the pdf list. If you want to give me the data I'd be happy to give you the numbers to try, then you can verify by doing the same check with the vehicle on the dyno..
50-40, 40-30, 30-20 times
Vehicle weight as accurate as possible
IE- If it is at 80MPH then you will want to take it to at least 100MPH. I have set the measurement in Supras and such up to 150MPH just to sure that we have enough room to get accurate measurements. Mustang has always told me that past the parasitic curve the numbers are not as accurate as you are not factoring in parasitic loss which seems to be big on the Mustangs.
Mitch
In order to get accurate data on the Mustang the parasitic curve needs to be calibrated past or up to the top MPH that you will be seeing.
Mitch
Mitch
Dyno's should just be used as a tool. I never understood why people get all hot and bothered over dyno numbers. I'd much rather get all hot and bothered over trap speeds.
figured i'd share here since i'm in a similar power range to a number of you folks.
had my stealth on a mustang dyno yesterday, made 432hp and 421tq.
tuned it on a dynojet 2 weeks ago, made 457hp and 424tq.
was cooler and a bit less humid 2 weeks ago... was surprised at the relatively small difference between the two.
I don't think I've ever actually laughed out loud while reading this site before.
