Ivey Tuned, AMS Bolt-ons, 93 octane, expectations on gains
i think that your HFC is already destroyed!! and he is blocking the way out! it happens to me! i took my HFC of my car and it was all red. take 5 mins and take it out and look at it!!! my HFC lasted not even a week and it was the UR one proof to 750hp....so check that out and put a TESTPIPE ON PLEASE LOL :-)
Something's wrong...and no one has mentioned the most common thing...boost leak
Compare your torque spike to this guy's graph...also tuned at Ivey's https://www.evolutionm.net/forums/ev...vey-tuned.html
You both have similar mods and your peak tq is at least 500rpm later, meaning ur peak boost is also later.
When I brought my friend's X to Ivey's he had a very large boost leak and could barely break 300whp with bolt ons and gsc s2 cams...we fixed the leak at the shop (coupler related) and bam...350whp. I had a very small boost leak from my VIII throttle body...had a dyno pull from before and after fixing it, and picked up a good 300rpm in spool. Boost leak test is a good place to start
We did a boost leak check, there was a leak which was repaired and after that she held boost fine.
I overlayed his with other cars I have done he isn't WAY off, but there is something up.
The customer installed alot of the parts himself so we would have to backtrack to figure out what is going on. I think he is bringing it back in.
Intake noise sounds like a ported shroud turbo, I have done plenty of cars with this setup NEVER heard one sound like this.
Sean
Sean
Why didn't you mention anything about the "unusual noise" in your first post? That is clearly the issue right there. Or maybe another boost leak as apparently there was one fixed during the tuning session. You already know what the problem is....
So...what is this post about again?
This is exactly why I'd rather pay the labor than pay for it in hp/tq numbers.. In my opinion. Hopefully it's not the high-flow because I'm bout to spend more money for it than the test pipe and would rather it not run worse lol.. Good Luck keep us posted!
But I mean to be clear, my initial question to the community was whether or not my dyno results were in the expected range, given my set of mods.
Fair point, but I mean with an intake, UICP, and catback installs, thats something anyone can do. not a lot of rocket science involved. I left the downpipe and the gauges to the pros. In retrospect I should have left the FMIC to the pros, but i didn't and I paid for it in terms of a boost leak for which Ivey was able to detect and repair.
Ivey tuned my car and was at 335whp/tq. Mods were very mild...
Turboback w/ test pipe
UICP
Drop in filter
Everything else stock.
