David's Evo X.. 607whp on FP BLACK
Old May 16, 2011 | 11:46 PM
MiTech's Avatar
Great job mike what injectors are you guys using
Old May 16, 2011 | 11:48 PM
AWD Motorsports's Avatar
Thanks guys!!
Im using FIC High impedance 1100
Mike
Old May 17, 2011 | 03:47 AM
EVO X 6950's Avatar
Thats beautiful, good job
Old May 17, 2011 | 04:04 AM
TheNEWB's Avatar
what the correction factor on that dyno? and what wastegate did you guys utilize for this build?
Nice#!
Old May 17, 2011 | 07:21 AM
murlo26's Avatar
FIC 1100's?
What are your duty cycles? Did you bump the base pressure I assume?
Old May 17, 2011 | 07:37 AM
scheides's Avatar
EvoM Moderator
Originally Posted by murlo26
FIC 1100's?
He said they were using a Buschur Double Pumper, I'm guessing those are pushing the 1100's a bit further than you'd expect out of a single pump. Definitely impressive though, they must still be maxed out!
Old May 17, 2011 | 07:40 AM
murlo26's Avatar
True, but that is still a lot, I'd assume upped base pressure otherwise that seems to be out of the range of the 1100's. However they probably are running their E85 nice and lean like E85 likes anyway, so that helps.
Old May 17, 2011 | 08:09 AM
KJ82's Avatar
Congrats on the new record...!
Old May 17, 2011 | 09:19 AM
ETS Michael's Avatar
Great Job Mike! Glad to be part of it.
Michael
Old May 17, 2011 | 09:29 AM
4g63smokinall4s's Avatar
Good stuff Mike!!
Old May 17, 2011 | 11:36 AM
RazorLab's Avatar
Originally Posted by AWD Motorsports
Thanks guys!!
Mike
Wait wut...
What base FP are you running for 1100's to even support this power level on E85?
55-65psi base?
Old May 17, 2011 | 11:43 AM
Originally Posted by razorlab
Wait wut...
55-65psi base?
I have to ask derek who was tuning.. We make 650whp on low impedance 1200s with FPR always.. so base should be close to 60.. Ill find out..
Old May 17, 2011 | 11:47 AM
murlo26's Avatar
Ok, that makes sense, I knew the base had to be up there. All is well in my mathematical mind lol
Old May 17, 2011 | 11:53 AM
Black Momba's Avatar
nice job AWD 600 whp must feel nice on a black
Old May 17, 2011 | 02:18 PM
darwin_evo's Avatar
Nice power
What's the idea behind running high base pressure Instead of bigger injectors?
