*** 2011 Evo X GSR Baseline Dyno ***
Old Aug 23, 2011 | 04:02 PM
  #31
oozkarao's Avatar
Haha I'm sure STi feels much faster with those ups and downs in torque since it would jerk you around and man-handle you :P
Originally Posted by glamcem
I am glad I went to the Dark Side I enjoy cookies
and now look at this ..
Old Aug 23, 2011 | 06:26 PM
  #32
Kracka's Avatar
The STI's acceleration looks exciting, you never know what you're going to get
Old Aug 23, 2011 | 07:09 PM
  #33
WarmMilk's Avatar
Originally Posted by Pimplay2
awesome results, i wonder what it would run with full bolts ons and factory map
here is my 2011 with Cosworth drop in, testpipe, and T1R catback (blue line is pretune, red is after), peak number pretune are 318whp/328wtq @ 26 psi. however, its not all about numbers, after the tune the throttle response got much much better, and the car even free revved faster
edit:
also have Spec Stage 2+ clutch and ACT StreetLite flywheel
Old Aug 23, 2011 | 07:10 PM
  #34
sslevo's Avatar
What are the details on the "cobb stage 1" ? Does this raise the boost at all? And other parts or just a tune?
Old Aug 23, 2011 | 07:42 PM
  #35
dazz's Avatar
Don't let the folks over on NASIOC know about this, they won't be a happy camper. :-)
Old Aug 23, 2011 | 09:31 PM
  #36
glamcem's Avatar
hahah very true
Old Aug 23, 2011 | 09:41 PM
  #37
glamcem's Avatar
edit:
I can tell by looking at are under the curve it seems like your torque curve moved to left and wider..
question is : what kind of EM you were running before the custom tune?
and what type of dyno is that? it seems like it reads little high since many people have to invest a FMIC and some other goodies to achieve this power levels...
Thanks in advance
Old Aug 24, 2011 | 08:10 AM
  #38
Kracka's Avatar
AFR & boost
Old Aug 24, 2011 | 08:46 AM
  #39
gabrod72's Avatar
Are these the same numbers you get with OTS Stage 1 for a 2010? Seems really high for an off the shelf 2010 stage 1 map. I can definitely feel a difference between stock 2010 and stage 1 though, but if 2010s hit 250whp~ish then this would mean a 40hp increase with an OTS map. Torque would be higher gain than 18wtq too.
+30whp/+18wtq
Old Aug 24, 2011 | 08:53 AM
  #40
Kracka's Avatar
All years Stage 1 OTS maps should yield about the same final results, each year the factory tune gets better so the gains are smaller to get to the same end result.
Old Aug 24, 2011 | 12:03 PM
  #41
WarmMilk's Avatar
Thanks in advance
I wouldn't say the tq curve moved, it just got bigger... everywhere...
whats EM? if you mean tune, then its the stock tune, only the mods I listed above
its a dynojet, it reads typical for a dynojet. here's a 2011 MR on the same dyno, stock and stock+tune. stock numbers are actually a bit lower than some other 2011's have tested. my evo put down 268 bone stock on a different dynojet
https://www.evolutionm.net/forums/ev...k-2011-mr.html
Old Aug 24, 2011 | 12:08 PM
  #42
Kracka's Avatar
EM = exhaust manifold
Old Aug 24, 2011 | 12:11 PM
  #43
WarmMilk's Avatar
thanks for schooling a noob...
stock mani, like I said, only the mods I listed above...
Old Aug 24, 2011 | 05:57 PM
  #44
oozkarao's Avatar
All previous year EVOs had about 24PSI target for Stage 1, but '11 Stage 1 OTS map from Cobb has 26/27 PSI target. I can understand all until '10 made the same power, but how come '11 make the same as well while pushing 2-3 more PSI?
Old Aug 24, 2011 | 06:35 PM
  #45
glamcem's Avatar
it's very interesting or we might add..
why do we need the additional boost to achieve same power goals on 11s? if the gains are identical
