Another Stock Turbo E85 - 363whp/428tq ?
Old Jul 13, 2011 | 09:58 AM
RazorLab's Avatar
Originally Posted by Supraboy1
Also the peak AFR of 15.8 is DANGEROUS. Even if for just a few seconds while under heavy boost, you ran lean that's bad.
Guys, please read the dyno sheets correctly if you are going to be so critical about them.
Originally Posted by tscompusa
that dyno has a really high CF, i forget what it is exactly, but its pretty high. it reads higher then a dynojet i believe.
Tobz mustang is 1.2 CF so this car really makes 302.5whp/356wtq
Old Jul 13, 2011 | 10:49 PM
tscompusa2's Avatar
holy crap! i can understand changing it alittle due to the elevation, but not that much.
Old Jul 14, 2011 | 07:04 PM
evo420's Avatar
lol.. Its fun to play with it and wack off in Virtual Dyno but not on a pro dyno.
Old Jul 14, 2011 | 08:11 PM
tobz's Avatar
Correction was 1.19.
It is a sniffer so leaner by a point in the tailpipe.
There is nothing to worry about
The x turbos at this elevation fall off really bad....because of that they make a great tq spike and fall drastically. That is why the HP is not as high as you wanted.
Old Jul 14, 2011 | 09:47 PM
rdwngs44's Avatar
Most CO dynos use a weather station which change the CF from about 1.16-2.24 so it's not TOBZ, it's just the weather station. Other dynos here are a set 1.15, regardless, it's just a tool.
Old Jul 14, 2011 | 10:13 PM
tscompusa2's Avatar
Im aware of the weather station, but i believe they have it locked in at a static CF for this dyno. correct me if im wrong tobz.
Old Jul 15, 2011 | 06:14 AM
Magnumpsi's Avatar
No the number changes it does not stay at one number. I have tuned many cars on his dyno and I know it does sway.
Mitch
Old Jul 15, 2011 | 08:36 AM
SilverEvoX's Avatar
Well based on the CF then I'd say the engine isn't necessarily in any unsafe zone considering real wtq is far below 400 which is considered the safe limit for the stock rods. I wouldn't run 31psi through a stock turbo if you paid me though...that's just pushing hot air and is the only reason the tq spiked so high also it can't be good for the turbo. Most people run 26-28psi on stock turbo after being tuned and you can still make great power at 26psi if it's setup right, EX:my sig @ 26psi with a stock downpipe
Old Jul 15, 2011 | 12:25 PM
tscompusa2's Avatar
but this is really high elevation, so your 26psi wont be as powerful where he lives. you cant forget about that.
Old Jul 15, 2011 | 12:26 PM
tscompusa2's Avatar
Mitch
thanks for clearing that up Mitch.
Old Jul 15, 2011 | 01:05 PM
SilverEvoX's Avatar
Well this is true however it doesn't negate the fact that you shouldn't be spinning the stock turbo to 31psi...it's WAY out of its efficiency range and wasn't designed to be run at that psi.
Old Jul 15, 2011 | 01:17 PM
RazorLab's Avatar
Can you show me a compressor map for the Evo 10 stock turbo? If you could factor in each 1,000 ft in elevation that would be great too.
Old Jul 15, 2011 | 02:44 PM
laksman91's Avatar
+1
QUANLOCO
E85 / Ethanol
Dec 21, 2021 09:38 PM
s2000-EvoX
Evo X Dyno Results
15
Apr 20, 2020 08:48 PM
gymnasty
E85 / Ethanol
162
May 7, 2018 03:52 PM
zcchenCT9A
E85 / Ethanol
Jul 22, 2011 07:04 AM
razorlab
32
Nov 8, 2008 08:57 AM
