Another Stock Turbo E85 - 363whp/428tq ?
Old Jul 12, 2011 | 08:48 PM
tavo_evo's Avatar
I just recently got tuned with this list of mods:
AMS FMIC
AMS UICP and LICP
MAP downpipe with O2 dump
Ichiba Test pipe
Top Speed PRO 1 Catback
Wallbro 255
1100cc FIC
Grimspeed 3 port
Cobb Intake
I noticed that my horsepower to the wheels was not what I was expecting but my torque is super high which feels awesome on the car. Any ideas or suggestion why is that? I got tuned at tobz and he did an amazing job; I'm happy with the results but I wonder why my graph is different from most stock turbo E85 evo tens around here
Old Jul 12, 2011 | 08:50 PM
Supraboy1's Avatar
Depends on which dyno, correction factor, and other factors.
Old Jul 12, 2011 | 09:02 PM
murlo26's Avatar
Very much so, tobz is one of the higher ones for sure.
Old Jul 12, 2011 | 09:04 PM
xezerax's Avatar
Can you post up a picture of the graph? That torque must be awesome but I would be a little nervous about it
Old Jul 12, 2011 | 09:22 PM
tavo_evo's Avatar
by that you mean that his dyno reads higher than usual? compared to the rest?
Old Jul 12, 2011 | 09:23 PM
tavo_evo's Avatar
Why be nervous about it? pushing the limits of the car?
Old Jul 12, 2011 | 09:26 PM
murlo26's Avatar
Not trying to start ****, but yes because he has a decent CF on it. No big deal, just take the numbers for the gains thats it.
Old Jul 12, 2011 | 09:32 PM
tavo_evo's Avatar
I'm going to take a picture of the graph and post it; this is my first time getting tuned so please understand my noobness
Old Jul 12, 2011 | 09:44 PM
tavo_evo's Avatar
Here is the graph; let me know what you think please
Attached Thumbnails Another Stock Turbo E85 - 363whp/428tq ?-photo-2.jpg
Old Jul 12, 2011 | 09:48 PM
murlo26's Avatar
12.6 is the min AFR? Seems pretty lean.
Old Jul 13, 2011 | 01:57 AM
redsun727's Avatar
stock internal??
Old Jul 13, 2011 | 04:07 AM
Supraboy1's Avatar
The peak of 31.3 psi on stock internals is high I'm my opinion. Also the peak AFR of 15.8 is DANGEROUS. Even if for just a few seconds while under heavy boost, you ran lean that's bad. My AFR is 11.8 to 12 across the board for comparison
Old Jul 13, 2011 | 04:57 AM
xezerax's Avatar
Yea I would be nervous about that kind of torque on stock rods. And for a mustang dyno those numbers are pretty high, but thats probably due to the CF like Murlo said.
Old Jul 13, 2011 | 07:09 AM
tscompusa2's Avatar
the 15.8 is probably from part throttle to wot for a split second.. regardless it can be avoided when the fuel maps mapped properly in that load area crossover.
that dyno has a really high CF, i forget what it is exactly, but its pretty high. it reads higher then a dynojet i believe.
if thats 12.5 on a tailpipe sniffer its actually around the 11.8-12 area anyways depending on how the sniffer reads he uses.
e85 runs a really cool intake charge as it is since the latent heat of vaporization is much higher.. egt's and everything will be much lower with it so theres more room for error when it comes to afr swings. the normal target i go for and most others is 11.8 after spoolup on a gasoline wideband.
Old Jul 13, 2011 | 07:28 AM
tavo_evo's Avatar
I am running stock internals; I also just purchased a wideband because it seems like from your comments that my engine is not on the safe side
He told me that this was a very conservative tune but the AFR is starting to worry me
