Rebuilt motor, ETS kit, 6262, E85
Old Oct 12, 2011 | 01:16 PM
Mr. Move's Avatar
the exact setup i want a built 6262 e-85 evo ughh lol
Old Oct 12, 2011 | 01:52 PM
Mr. Move's Avatar
Do you have any transmission work done? and what do you use this setup for?
Old Oct 13, 2011 | 05:54 PM
RB185AFM's Avatar
Nice, makes me want to upgrade my fuel system sooner than later.
Old Oct 13, 2011 | 06:40 PM
2003evo8's Avatar
have u taken it to the track yet
Old Oct 13, 2011 | 07:17 PM
EvoX-11's Avatar
wait, why 5400 rpms at 80mph?
Old Oct 13, 2011 | 07:20 PM
JTEVO2932's Avatar
wow nice work!
Old Oct 15, 2011 | 04:20 AM
EvoX2NR's Avatar
4th gear
I tried to before I had to go out on the ship, but the weather and work didn't cooperate. I do plan on going to Force-Fed's southeastern nationals event in November.
Just a shep tranny (stock t-case and rear diff at the moment). The car has been used for everything I can get out to. I am going to lean more towards road racing after the force fed event (I just want to get that time slip).
Old Oct 15, 2011 | 05:04 AM
1800bigk's Avatar
Effing beast, must be awesome to drive.
Old Oct 15, 2011 | 06:24 AM
wwcagedevo8's Avatar
What rpm do you get full boost? How much timing where you running up top?
Old Nov 6, 2011 | 07:23 AM
mitsael's Avatar
Hey bro what those your engine build consist off ???
Old Nov 6, 2011 | 06:44 PM
Babi@Force-Fed's Avatar
Enough...
Old Nov 6, 2011 | 06:54 PM
lazer's Avatar
hey guys am new here but need some help i have a evo 5 rs that ive jus done the monster build 4g64 bottom 4g63 top but after the brake in im hearing a strange noise when the engine goes under load its at different rpm for each gear like in first gear im hearing it at a lower rmp than in fourth gear ive also done the blancer shaft removal can anyone tell me what is causing this noise thanks in advance
Old Nov 6, 2011 | 07:05 PM
EvoIIIAj's Avatar
Nice power, damn!
You're in the wrong thread...
Old Nov 6, 2011 | 07:08 PM
EvoX2NR's Avatar
Originally Posted by Babi@Force-Fed
Enough...
If I don't pull wastegate duty cycle at 5000 rpm, I see 38-40 psi at around 5200-5300.
it's in the first post, but the internals consist of:
wiseco piston (thicker pins)
manely I beam rods
ACL bearings
Buschur head (ported, supertech dual valve springs)
GSC S2 cams
Old Nov 7, 2011 | 12:08 PM
Guru's Avatar
I got 28 PSI on my old HTA 3582R turbo setup around 4400 RPM. Not sure how much max power those make since I only used pump gas but would love to see overlay graph of bost response. It looks like a very nice option. Great job! That is insane power for E85!
