BeaterX hits MAP's DynoJet with an EF4: 599whp
Ran the car at our MitsuStyle.com Fall Dyno day last weekend. Story of my life, car is down a bit on power....I turned the MBC up but forgot to adjust the error correction so WGDC got pulled to 30% up top, so 35psi taper to 30@8000.
I've done VDR pulls up to 630whp but that was months ago, different weather, etc...who knows. Car is fun as hell though! Enjoy.
Full mod list:
Primo 3.5" intake/maf with aFe filter
MAP EF4 turbocharger
Pierburg BCS / Hallman Pro MBC hybrid boost control setup
Custom 2.5" UICP
Buschur Race FMIC
Primo 2.75" LICP
MAP Rev3 intake manifold
Mil.spec throttle body
Cobb BOV
DB Performance Ported Head w/ 1.0mm oversized valves and supertech dual valvesprings
Kelford 214-B cams
MAP stage1.5 shortblock w/ MAP X-beam rods and JE pistons (20,000 miles and counting!)
FiD tubular exhaust manifold
Ported turbo hotside
MAP O2-elim downpipe
T1R resonated testpipe
Magnaflow catback
Fuel:
Walbro 400 fuel pump (non-e85)
Kenne Bell Boost-a-pump
Boomba Fuel Rail
Fuel Injector Clinic 1680cc high impedance injectors
e85 fuel
Build thread:
https://www.evolutionm.net/forums/al...-thus-far.html
Full mod list:
Custom 2.5" UICP
Buschur Race FMIC
Primo 2.75" LICP
Cobb BOV
Kelford 214-B cams
Magnaflow catback
Fuel:
Boomba Fuel Rail
e85 fuel
Build thread:
I'm guessing your downpipe dumps into the atmosphere. Looks like you had a pretty good spark behind the turbo! Good Numbers and congrats on saving the Evo from the previous owner. Can't really call her a Beater X anymore!
Sure can, I drive it every day and it gets washed once every few months at best
. Winter included!
Ya someone else pointed out that flash to me as well...I have a recirculated downpipe so I'm not sure if it's the breather, a leaky gasket, etc. I'll check my turbo-to-manifold bolts.
. Winter included!Ya someone else pointed out that flash to me as well...I have a recirculated downpipe so I'm not sure if it's the breather, a leaky gasket, etc. I'll check my turbo-to-manifold bolts.
Thanks!
Grats scheides, glad your car is running strong! I rarely post up stuff on this site and was disappointed with my **** so didn't feel like it, but now seeing you posting your stuff I feel giddy a bit
TnC time dude! Spring cruise! Then drinking galore!
Lol I just moved back from Arizona around 3 weeks ago which is right when I joined the EvoMN so it kinda slipped my mind lol. Oh well, I'm sure there will be another event coming up soon enough.
Thanks!
Hell yea! This setup is VERY drivable cruising around under 4000 rpm. 5th gear passing at 3000rpm is very capable, and putzing around town is nice and smooth. There's enough airflow from 3000-4000 that you can have nice smooth linear acceleration that doesn't at all feel like a wimply 2.0L. All is fine and well then just hang onto a gear and pin the as you pass 3500rpm and 8500rpm is there before you know it.
Nice numbers Chris. Having seen the BeaterX in person, people cannot appreciate what a sleeper this car is. Sans rear wing, it looks quite unassuming. Joshua said you are using a Kenne Bell Boost a pump. Are you using this in conjunction with the Walbro 400?
