2012 GSR - 311/312 - tuned by FFTec
Old Nov 14, 2012 | 04:35 PM
arximus's Avatar
Originally Posted by mp72
An evo X doesn't like to idle that low with big injectors. Have Sean bring the idle up to about 1k rpm.
I was having the same issue after my tune. When warm, my idle would bounce really low and I would get random misfire codes on a regular basis. I raised my idle so it bounces between 900-1000 rpm and I've never had the check engine light come on again.
Thanks man, Sean did end up raising the idle but once in a while it still bounces. Just curious if it was just my car or other big injector guys as well.
Those are some nice numbers off the 2010, sad mine didnt make it as high.
Cheers~
Old Nov 14, 2012 | 09:16 PM
mp72's Avatar
Cheers~
With big injectors and a cone filter intake, your idle will bounce and it's completely normal. With mine, the idle bounce is not as big since it was raised to 1k rpm.
My car was tuned at the old FFTec shop before the dyno was moved to it's new location. I'm sure moving a dyno will have an effect on the number. Dyno numbers are just a number unless you have a baseline to go off of. Quality parts and the tune is what's important.
If you want to see my dyno chart from Sean's tune, I posted it when I was new to evoM. If you can search my post history you should find it.
Old Nov 25, 2012 | 01:50 PM
clichere1's Avatar
Thank you guys for your contribution
mitsubeastlee
Aug 25, 2016 07:56 PM
Jeepyedo
For Sale - Cars For Sale
Aug 11, 2016 05:05 AM
apoopoo999
Sep 26, 2015 01:29 PM
Tri
Sep 21, 2015 11:26 AM
clichere1
Jan 12, 2013 08:21 AM
