FLEX FUEL v2.0!!! e_kobz's Evo X GSR 18k, MAP cast mani, bolt-on's
2006EvoIXer (Jun 13, 2017)
#48
Where did you install your wideband sensor?
The reason I asked is because I just found out the exhaust manifold is not good for the life of UEGO sensor. I wanted to monitor cylinders 3 & 4 specifically. Guess I'll need an EGT for this. I'll install bung for UEGO on DP.
#50
question for you hopefully i dont get flamed for this one from the online trolls but was wondering what made you pick this manifold vs the others out there that are stock replacements. this one is consideriably cheaper then the others at 500 or so and the other start off around 800+... in your research they gave the same performance or? slightlyu lower?
#51
Only issue with the MAP manifold that I can see is it's a fairly popular item so they're always on back order.
#52
It's a valid question that I get asked quite a bit. The answer is I wanted to retain the oem heat shield, that was probably the main. Aside from that I liked the price (I got in on the introductory price when it first came out ), how robust it is, and the larger runners.
2006EvoIXer (Jun 18, 2017)
#55
Similar to the MAP manifold on my X, one of the reasons I decided to get the FP manifold was because of the price. They ran a special a couple years back where they sold blemished manifolds for like $150 shipped or something. It performed just like a non blemished one but it had some discoloring or something. I didn't care as once it gets some heat in it it'll start to change color anyways.
#56
