Evo x gsr 2008 703WHP on E77
Old May 22, 2020 | 12:11 PM
fel1979's Avatar
FUEL BLEND E-77 RESULTS: 703 WHP@7547 / 65.74KG/M@5902 @ 30PSI.
Soon will be running a higher boost to see how much more it makes.
MODS:
MoTeC M150 / MoTEC C1212 Dash / LTCD / MoTeC Keypad
4x ID 1050x Primaries
4x ID 1700x Secondaries
Built Motor 2.2 Big Bore
Precision 6266 Gen2 - Vband 0.82
AMS Intercooler
AMS Heads 1mm oversize valves with GSC S3 Cam
Tial MV-R Wastegate
All other supporting mods.
View this post on Instagram
Old May 22, 2020 | 02:59 PM
RazorLab's Avatar
That dash 🙌
Old Jun 3, 2020 | 10:32 PM
robos4's Avatar
Great results!!
Can I ask - what dyno was this on?
Why did you stop the run at 8k? Would have thought this setup can keep gaining up to 8.7k at least.
Rob
Old Jun 4, 2020 | 10:59 AM
LetsGetThisDone's Avatar
Nice setup. Love that dash, good power results too.
Only question, why add the complexity of 8 injectors when one set of 2000's would've been plenty of fuel? With the motec tuning drivability would've been a breeze even on big injectors.
Old Jun 10, 2020 | 02:41 PM
Abacus's Avatar
The smaller injectors will idle /drive much better. A big injector can only work so well at minimum pulse width. An ID2000 is going to have a much harder time at idle/low load controlling fuel.
I went from ID1300 to ID1700 a few years back. You could see it in the log and the car wasn't as crisp if you were really looking. Still drove well but there is only so much you can do on a larger injector.
OP- Great combination of parts and MoTec goodness. Epic build . Car looks and performs well.
Old Jun 10, 2020 | 03:01 PM
RazorLab's Avatar
Gotta agree here. The ID1300's are by far the best injectors I have ever tuned and used. Super smooth overall. I had to do a ton of tweaking when I moved to ID1700's and they still aren't the same as the ID1300's.
I still have yet to see a set of 2kcc's drive anywhere close to my standards. Driveable? Yes. Smooth and silky? Not at all.
Old Jun 10, 2020 | 03:45 PM
I've never really had complaints with ID or FIC 2000's when properly tuned on built motor They just take some tuning time. If anything its becasue these car are usually rinning a 5bar map which is definitely meh on a stock ECU if thats whats in the car. Stand alone and 2000's are usually great.
I can say for certain that ID 1700's do not work or tune nearly as well as FIC 1650's from a drivability standpoint.
Old Jun 10, 2020 | 04:53 PM
Abacus's Avatar
Its one of those things. Everyone has a different idea of "OK" based on what they know and are comfortable with. You can cover up alot of things with extra fuel so the car drives well. We still live in an incredible time where we can complain about how good/bad huge injectors are on 1000hp 4 cylinder street cars. LOL
If I was building a high hp street car I'd follow a similar path as the OP. Have the best of both worlds.
Old Jun 14, 2020 | 08:38 PM
fel1979's Avatar
Originally Posted by robos4
Great results!!
Rob
Indeed it was gaining.. I just stopped because I wanted to finished the inside of the car..
Dyno is a Brazilian brand, it reads pretty similar to mustang dynos without correction.
Will be back with a bit more boost and reving to 8.8k.
Old Jun 14, 2020 | 08:43 PM
fel1979's Avatar
Thanks.. driveability it was my main goal. The cars was previously with a set of ID 1.700 as primaries. But it wasn't good as I expected.. with 1000 cc, on the primaries it runs so much better.
And I don't think is wasn't such a hassle to install 8 injectors. I loved the results.
Old Sep 23, 2024 | 05:26 PM
Abyram's Avatar
Nice build. Dual injectors defiantly is the best of both worlds though I haven’t experienced any drivability issues on standalone ECU’s more on stock ECU’s.
dsrtibb
Evo X Dyno Results
Sep 8, 2016 12:12 PM
MadBoostedEvo
Evo X Dyno Results
Apr 6, 2016 02:26 PM
MadBoostedEvo
Evo X Dyno Results
35
Jan 13, 2016 09:56 AM
kkakonn
Evo X Dyno Results
Feb 13, 2014 12:24 AM
calhoun
For Sale - Cars For Sale
24
Feb 25, 2012 10:03 AM
