Boot Install
Old Dec 16, 2008 | 07:54 PM
vrrroommm's Avatar
the head unit is kenwood DDX7039, with GPS navi unit. I'm not 100% happy with it, tho. I'd rather the Pioneer AVH-p6050dvd. Has more functions for time-alignment, and sound adjustments are better, I think.
Old Jan 12, 2009 | 06:53 PM
rageagtm's Avatar
any trick to mounting your amps in that locations. Your system is VERY clean, I want the exact same haha. I will probably just do a 5 channel however, mated to the stock navi with a audiocontrol unit?
Old Jan 14, 2009 | 12:38 AM
vrrroommm's Avatar
The only "trick" is to make sure that the thin plywood/mdf that you use to mount the amp is securely BOLTED to the bottom of the "boot tray" (i dunno what you call that top section....). Just a normal screw would ultimately shake loose, especially since the X is a bit (or a lot) bumpy depending on the suspension you have.
De 2 audison amps that I have are quite light and small.. not too heavy. A 5-channel amp may be a bit heavy for that tray...
Share your pics when you're done...!!
Force-Fed Performance
85
Sep 11, 2013 02:21 AM
Evo 'For Sale' Services
13
Mar 28, 2013 07:50 AM
vrrroommm
15
Apr 22, 2010 12:04 AM
E VOL IX
Southeast Region
Jul 25, 2008 06:45 PM
Spun Autosports
Evo 'For Sale' Suspension / Brakes / Handling
48
Oct 15, 2007 03:40 AM
