Rockford Amp swap??
Old Mar 3, 2009 | 12:43 PM
EmperorX's Avatar
Rockford Amp swap??
Hey guys do you know if this setup wil work??
aftermarket radio
metra harness (Mito-01) Works for eclispe or endevor
Eclipse or Endevor Rockford amp.
Basically, will an eclipse or endevor amp work in our cars?
Old Mar 3, 2009 | 12:51 PM
c_reber's Avatar
I don't think it will work. I'm guessing the plugs on the eclipse/endevor amp are different. Also the amp turn-on is done through the CANbus system, which is also going to be different in the eclipse/endevor.
I would just forget the wiring harness and go with an aftermarket amp. Shouldn't be too much more expensive than a factory mitsubishi amplifier. Not plug and play, but not too difficult to wire up.
Old Mar 3, 2009 | 12:54 PM
EmperorX's Avatar
Well the CANbus wouldnt matter beacuse im not using the stock radio right? Im just worried about the plugs...
Old Mar 3, 2009 | 01:07 PM
c_reber's Avatar
Not sure here, but I'd have to think the CANbus in the eclipse or endevor is different than the lancer. I mean the metra harness still "tells" the canbus to turn the amp on. And I think it would be a different wire/resistance in a different car. I could be wrong, and everything you asked about could work fine. Just a guess.
Did you find a good deal on an amp or something? I'm just curious as to why you want to use the factory amp when it's still underpowered.
Old Mar 3, 2009 | 02:00 PM
EmperorX's Avatar
Well the harness sends a signal to the Eclipse and endevor amp but not ours. I dont really play my music really loud so i'm happy witht he stock system. i jsut want to put my D3 in. Plus what kinda of amp woud i use to power 8 speakers and a sub?
Old Mar 3, 2009 | 02:36 PM
c_reber's Avatar
Hey, I hear ya man, I have my D3 sitting in the garage waiting for me to get a new amp. Can't wait to install it! I'm probably going to get the T600-4 amp or if I can get a deal, the RF power 1000 5 channel amp. But i'm upgrading the speakers and sub as well, so you probably may not need this much power.
As for an aftermarket amp, you could use a 4 channel, or a 5 channel, or even get a 2 or mono just for the sub, and run the speakers from the deck. The latter being the least expensive.
I would do a search on here and see what other people have done.
Old Mar 3, 2009 | 04:19 PM
EmperorX's Avatar
I dont think i can run 8 speakers off the D3. A 5 channel would work but its expensive...plus thats a lot of wiring. haha if i can get an eclipse amp for cheap im just gonna try it out and see if it works
Old Mar 3, 2009 | 04:40 PM
c_reber's Avatar
You can easily run 8 speakers from the D3. It's really only 4 speakers w/ tweeters. Just wire them in series at 8ohms. They may already be in series at the factory amp. In fact that might be what I have to do until I have the $ to buy everything. I'm just lazy.
Old Mar 3, 2009 | 04:49 PM
EmperorX's Avatar
HAHA im lazy and cheap! so im trying to figues out how to do this with as little work as possible. how do i run the tweeters and the speakers? not good at audio stuff..
Old Mar 25, 2009 | 09:44 AM
boostin20's Avatar
This is series, just imagine one is a tweeter. I've never wired tweeters like that before, but in theory it should work fine.
New question, is there just pos and neg wires going into the sub box? If not, how many wires are there? I haven't pulled it apart yet and don't want to do it for no reason.
reven8egts
Oct 14, 2014 10:32 PM
merlin.oz
May 22, 2014 08:23 PM
malymabl97
47
Feb 4, 2010 04:06 PM
Xenozx
10
Nov 25, 2009 10:25 AM
bluesox_68
Canadian Forum
23
Nov 27, 2007 08:00 PM
