Installed my Pioneer AVIC F-series
Old May 9, 2009 | 09:21 PM
  #31
REDEVO08's Avatar
yea 2.0
Old May 9, 2009 | 09:34 PM
  #32
wiretap's Avatar
Originally Posted by REDEVO08
mine is sorta the same..i am tryin to find a way to get rid of it
To get rid of it, you'll have to have a better ground with less noise coming through it.
Originally Posted by Tonic25
Did you upgrade the map on it?
I'm doing the patched ezrider.exe + 2008.4 maps + 2008.10 POI's tomorrow.
Today I made some custom sound schemes (button click noises, etc), updated my XM logos, added the branded POI logos, and messed with the navigation UI/ini settings.
Old May 9, 2009 | 11:29 PM
  #33
REDEVO08's Avatar
its grounded right behind the radio to the bolt on that cross beam
Old May 10, 2009 | 11:30 AM
  #34
Greedy_son's Avatar
Can you put up some pictures of you custom setup?
I placed my mic in the same location you did. Works great A+, i would recommend this location for anyone with a bluetooth mic.
Old May 10, 2009 | 11:40 AM
  #35
wiretap's Avatar
You can find all the hacks and pictures on AVIC411.com.
Old May 11, 2009 | 05:21 AM
  #36
reggiesd's Avatar
nice set up!
Old May 11, 2009 | 06:50 PM
  #37
wiretap's Avatar
Thanks. =D
Old Jun 3, 2009 | 01:51 AM
  #38
jump23's Avatar
reverse and parking wires???
I'm installing an Eclipse AVN726E and hoping you can help...
I got everything except where to wire the reverse and parking brake wires. I have a MR and it has a "extra connector" for the OEM nav so I imagine I can tap into those wires if I can figure out what they are.
Any idea which wires are for parking and reverse?
Old Jun 3, 2009 | 02:24 AM
  #39
wiretap's Avatar
The parking brake is easy to find.. it's connected right to the parking brake under the center console if you take the cupholders out. As far as reverse, I don't know. Just run a wire to the trunk and connect to the +12v reverse bulb wire.. it's white I believe.
Old Jun 3, 2009 | 02:40 AM
  #40
Domolution's Avatar
Wow...that looks REAL clean! I like it alott.....i am just gonna say i am jealous!
Everything you did was legit, just admiring your work, car, and Balling Pioneer F-Serious, haha!
Old Jun 3, 2009 | 03:36 AM
  #41
jump23's Avatar
hey, thanks for the quick response!
Yeah, I was hoping to avoid running wires anywhere so I was really hoping that parking and reverse would be on that extra plug. You would think that since this is the only extra plug that is used by the OEM nav unit, that it would have the necessary nav wires which are usually parking brake, reverse and VSS. The good news is that the Eclipse unit does not need the speed sensor wires. So I just need to figure out the reverse and parking.
thanks again
Old Jun 3, 2009 | 03:41 AM
  #42
i64X's Avatar
The F700 didn't need the speed sensor wires either. My old AVIC-D1 did. The AVIC-D1, because of this, was more accurate as far as nav goes than the F700. I wish the F700 had a speed sensor wire, as well as a built in compass. In tight spots, it doesn't know which direction the car is facing.
Old Jun 3, 2009 | 01:35 PM
  #43
wiretap's Avatar
@i64X.. The F700 has a wire for VSS. I didn't hook it up though.
@jump23.. I don't have the pinout of that nav harness. I'm sure all the wires are on there.
Old Jun 3, 2009 | 03:05 PM
  #44
i64X's Avatar
Mine didn't. It says in the manual that the F700 doesn't require this wire and it wasn't in my harness. I've got the MITO-02 so that supplied a VSS wire and a reverse lead. Oh well, it still works. :-)
Old Jun 23, 2009 | 10:00 AM
  #45
ice1874193's Avatar
my x has the factory xm - just unplug the xm connection and plug into the pioneer and i'm all set?
**edit - sirius radio
