What Amp for stock system?
Old Dec 12, 2009 | 03:00 PM
Riz5's Avatar
Hi guys,
I was trying to upgrade my system and just wanted to change the Amp. I think the stock RF system isn't really that loud. I don't want to do too much, just hoping to get some more volume and punch out of it. Any recommendations?? Oh and I wanted to buy something that isn't too expensive, around 300-500 dollars.
Thanks.
Old Dec 12, 2009 | 05:29 PM
atombomb33's Avatar
EvoM Community Team
Any of these would work...
http://www.crutchfield.com/g_120/Amp...|FF5%40Channel
Old Dec 12, 2009 | 05:41 PM
SqEvoVIII's Avatar
I don't own a X but I wouldn't run factory speakers.... even the RF factory speakers off a bigger amp. Most factory systems are designed to handle the power they're given and not much more. I wouldn't put in a new amp if you aren't going to change out the speakers. Plus if you run a 5 channel amp you are going to need either a JL cleansweep or RF 3Sixty.1 or something simmilar to connect it to the factory system and get good signal to that amp so you actually improve your sound. But thats just my .02...
Old Dec 12, 2009 | 05:49 PM
WWIXMR's Avatar
Would that be plug-n-play? Would you need to get anything else if you wanted to switch stock amp? Sorry, I suck at car audio.
Old Dec 13, 2009 | 07:33 AM
atombomb33's Avatar
EvoM Community Team
Actually, just an upgraded amp is a HUGE improvement in the Evo X. Normally, I would agree with you about not keeping the stock speakers, but they are fine. Not competition-quality fine, but fine. The amp is the weak link in the system and really is a problem. Once you replace it, the system wakes up.
You don't need a cleansweep or the RF 360 if you get an amp with speaker inputs. If the amp only has RCA, then you will need a cleansweep or another line-level converter.
In the end will just upgrading the amp be a competition system? Heck no. But, it is a HUGE improvment for minimal dollars spent that would satisfy the majority of Evo X owners who aren't true audiophiles.
Old Dec 13, 2009 | 07:36 AM
atombomb33's Avatar
EvoM Community Team
Depends on which amp you choose.
If the amp accepts speaker level inputs, then you'll need to cut some wires from the existing Rockford amp and run them into the new amp. Then you'll need to connect the existing speaker wires to the new amp.
If the amp accepts RCA inputs (only), then you'll need a line-level converter like the JL Audio Cleansweep or something similar. Then you'll need to cut some wires from the existing Rockford amp and run them into the line-level converter. Then run RCAs into the new amp. Then you'll need to connect the existing speaker wires to the new amp.
Either amp you choose will need a power/ground wiring kit to connect power to the battery.
Call Crutchfield or visit a local car audio store and tell them your plan. They'll be able to help you find something that will work in your car.
Old Dec 13, 2009 | 01:07 PM
Tractionlimit's Avatar
Good advice here. Are you refering to the 'premium' RF sound package with six disc and sub in the truck? I also don't know much about audio, but am not that impressed with the amount of punch I get out of the stock sub.
Old Dec 13, 2009 | 01:31 PM
boostin20's Avatar
Lets us know what you decide.
Old Dec 13, 2009 | 02:00 PM
Riz5's Avatar
Yes, I'm talking about the premium RF sound package but I have a Navi also.
I will.
Old Dec 13, 2009 | 02:06 PM
So you're keeping the stock sub?
Old Dec 13, 2009 | 02:20 PM
Clipse3GT's Avatar
Would something like this work?
http://www.crutchfield.com/p_500MRPF...00.html?tp=115
Old Dec 13, 2009 | 02:22 PM
big boss's Avatar
Originally Posted by Riz5
Hi guys,
Thanks.
thats very true! Stock AMP has no Output POWER! SO I went to AL&ED's Bought a ROCKFORDFOSGATE Punch 4-Channel Amp item# P400-4 Its running all my Speakers and Sub! I even upgraded my stock Sub to a JL W1 hits alil harder to
Old Dec 13, 2009 | 02:36 PM
atombomb33's Avatar
EvoM Community Team
Originally Posted by Clipse3GT
Yeah, you could make that work. But, the wiring configuration is going to be a little weird unless you don't plan to run the rear door speakers.
If you can, try to go with a true 5-channel amp. That way you can power the front and rear door speakers with 4 channels and the sub with the 5th dedicated sub channel. Will work best.
Old Dec 13, 2009 | 03:10 PM
Clipse3GT's Avatar
Thanks any cheap recommendations... Plan on keeping stock head unit and speakers.
Old Dec 13, 2009 | 03:43 PM
atombomb33's Avatar
EvoM Community Team
Check the link in post #2. The "cheapest" is $350 which is a good price. There are probably cheaper amps out there (probably at Best Buy), but none that I'm aware of.
