RCA output with MMCS
Old Mar 10, 2010 | 04:45 AM
JDMonster's Avatar
Im about to install a Sub and amp into my MR and I need to figure out how guys are getting a RCA output on there car so I can run my amp.
Old Mar 10, 2010 | 05:42 AM
mrMTB's Avatar
If you have the RF package with amp, this would probably be a good thing for you to look through...
https://www.evolutionm.net/forums/ev...-amp-info.html
Even if you don't, I imagine that this would give you enough information to figure out the colors of the sub output on the MMCS side.
Old Mar 10, 2010 | 06:03 AM
JDMonster's Avatar
I dont have the factory Fosgate system so no factory amp. I was looking at the JL Cleansweep but it doesnt appear to have a remote turn on for my after market amp. what other options are there?
Old Mar 10, 2010 | 08:24 AM
Webman's Avatar
That's not true... It does have remote turn on, even a device that you can buy that will detect audio signals and send a turn on.
Old Mar 10, 2010 | 11:30 PM
JDMonster's Avatar
Ok then cleansweep it is. My custom fiberglass box will be finished tomorrow and Fiberglass amp rack finished the next day
Old Mar 11, 2010 | 04:32 PM
Spoonie's Avatar
Do a search. The head unit has a low level 2-channel output. You can cut the wires and create your own RCAs
Old Mar 12, 2010 | 08:45 AM
Webman's Avatar
You only NEED the cleansweep if the signal from the deck is already amplified.
That extra box I was talking about is the CL-LSA (CleanSweep load sensing turn-on trigger)
Old Nov 11, 2012 | 12:17 AM
Cyp's Avatar
Cyp
Any links or info on this?
Old Nov 11, 2012 | 10:02 AM
Octane Blue's Avatar
Buy a line out converter and take signal from a rear speaker.
They look like this-
Old Nov 11, 2012 | 10:52 PM
Cyp's Avatar
Cyp
^ picture doesn't work
Old Jan 26, 2013 | 07:47 PM
EvoNoob00's Avatar
im in the same boat, looking to install a sub/amp to my stock radio. Any one got pictures of what wires to tap into to get the line out converter for the RCAs
Old Jan 26, 2013 | 08:13 PM
ninja99's Avatar
I would tap the rear speakers for the LOC. There's a speaker wire diagram over on they other forum.
http://www.evoxforums.com/forums/showthread.php?t=27486
The remote turn on can come from any 12v source. I would run it from the fusebox using an add-a-fuse on the cigarette lighter fuse or something. I used to throw a switch in line so i can turn the amp on and off if i wanted but that's not required.
Old Feb 7, 2013 | 03:11 PM
clayt006's Avatar
Run a line out converter from the stock RF amp under the drivers seat
Old Feb 8, 2013 | 02:07 PM
EvoNoob00's Avatar
thanks for the tip! much easier then having to pull out the stereo
Old Feb 8, 2013 | 02:18 PM
ninja99's Avatar
Works if your have the RF system. Otherwise, best bet is to pull out the stereo, which is pretty easy.
