Steering wheel controls with Carpc
Old Dec 25, 2010 | 08:38 PM
bakerunc22's Avatar
I wanted to know if anyone had any luck with being able to keep the steering wheel controls with a carpc?
Old Dec 26, 2010 | 08:07 AM
wiretap's Avatar
You could. It all depends how you have your sound setup. The best way is to use the PAC SWI-PS adapter and wire it into your harness.. then use a CarPC screen that has an actual amp & harness that can utilize it (assuming you aren't tapping into the Rockford system. I recommend this screen: http://revo-sys.com/65_inch_double_d...pc_monitor.php
Old Dec 26, 2010 | 10:59 AM
bakerunc22's Avatar
Well see that where the funs comes in cause for right now I am planning on using the factory amp. I have looked at the PAC adapter but wasn't sure if it would work. I was planning on using the following setup:
intel DH57JG board
M4 psu
Sata dvd drive for laptop
Centrafuse front end
Biggest things are keeping the factory steering wheel controls right now. Ideas ?
Old Dec 26, 2010 | 07:53 PM
wiretap's Avatar
If you're going straight into the factory amp without going into the SWI-PS adapter first, I don't think that will work because it is already past the point where the volume is controlled.
Old Dec 26, 2010 | 08:28 PM
bakerunc22's Avatar
By past that point what do you mean? what am i missing, sorry. I've looked at the pac and axxess modules but will they recognize the pc, as i have read that the modules do recognize sony pioneer etc. Just point me in the right direction and perhaps the easiest path?
Thanks Wire
Old Dec 27, 2010 | 05:06 AM
wiretap's Avatar
I already did.
Old Dec 27, 2010 | 11:29 AM
bakerunc22's Avatar
ok, well the screen that you said to use, would rather use the lilliput 669GL-70NP in my setup no way to utilize this?
Old Dec 27, 2010 | 01:16 PM
wiretap's Avatar
Input to your amp is a function of the volume output of the CarPC.. Tell me, how would you get the PAC SWI-PS adapter to control your volume within your operating system? You can't.. that's why you need a headunit screen with a built in amp and wiring harness you can tap into.
Old Dec 27, 2010 | 01:19 PM
bakerunc22's Avatar
Thats what im trying to figure out...if you took rca cables and ran splitters from the back of the motherboard and spliced them and then soldered the ends to the correct wires on the harness for front rear speakers etc. Would this work?
Old Dec 27, 2010 | 01:21 PM
wiretap's Avatar
I believe the harness needs an amplified signal.. the signal coming out of the PC is just enough for headphones, or the sensitivity of an amp input. But.. go ahead and try it and report back your findings for us.
Old Dec 27, 2010 | 01:28 PM
bakerunc22's Avatar
hmm thats a thought. I have seen some posts where people have used the AUX port and just stuck the factory unit behind the HVAC, but don't see if you had 5.1 channel audio how this would work?
Old Dec 27, 2010 | 01:37 PM
wiretap's Avatar
You only need stereo sound.
Old Dec 27, 2010 | 01:41 PM
bakerunc22's Avatar
got ya, so the intel board has Intel High Definition Audio (8 channels), so I'm guessing just use the front and rear channels?
Old Dec 27, 2010 | 01:48 PM
wiretap's Avatar
Yeah, the green analog connector.
Old Dec 27, 2010 | 01:52 PM
bakerunc22's Avatar
sweet so theres a breakthrough, so if I could possibly relocate the factory radio somewhere I wouldn't even have to worry about a headache perhaps
Haitham
Jun 11, 2017 03:34 PM
jaredh
73
May 28, 2010 03:47 PM
smanders
Apr 13, 2009 08:42 PM
BlackonBlack2
Sep 18, 2007 09:53 PM
highvoltz
For Sale - Cars For Sale
Feb 24, 2007 11:25 AM
