HID Upgrades for the Evo X
Old Mar 7, 2011 | 02:02 PM
airborne703's Avatar
I didnt get a chance to get the SS Package since I bought one of the first evo X's on the lot. Now I want to upgrade the headlights but have heard bad things about aftermarket headlights that you can buy. I was told the best way to go is to get an HID kit. Now my question is can the stock Evo x handle an HID upgrade or does the headlights housing give off a weird beam? I am open to any suggestions as far as what company and product to get.
Old Mar 7, 2011 | 02:22 PM
wiretap's Avatar
I did an HID upgrade in the reflector housings.. you do get some glare, but it isn't that bad. Just angle the headlights down a bit. It isn't ideal, but it works. You will have to disable DRL because it sends a square wave which causes digital ballasts to turn off and not allow the HIDs to come on. A way around that is to either turn on the headlights before you drop the parking brake, or disable DRL's by rewiring a few things. If you do a search, there is a how-to for the DRL bypass.
Old Mar 12, 2011 | 07:40 AM
nismo1118's Avatar
If possible just try and get the stock HID units, I love mine can never go back now
Old Mar 12, 2011 | 08:39 AM
HudsonFalcon's Avatar
Agreed. I bought the stockers for my non-SSS X and other than the flicker issue I love them.
Old Mar 12, 2011 | 10:06 AM
stealthevoX's Avatar
What's the flicker issue?
Old Mar 12, 2011 | 11:24 AM
Hakke's Avatar
drl voltage doesnt fully fire the hid bulbs so it flickers and they eventually blow. i just bought i drl bypass harness and hid kit
Old Mar 12, 2011 | 12:10 PM
Sir Kyle's Avatar
Has anyone retrofited projectors into their non SSS headlights?
Old Mar 12, 2011 | 02:38 PM
MRevolicious's Avatar
You mean you brought factory HIDs from Mitsubishi and put them into your non-SSS headlights? with no problems at all? I only ask cause I'm looking for HIDs for my non-SSS as well
Old Mar 12, 2011 | 06:26 PM
Not quite. I purchased OEM HID headlights and put them into my non-SSS vehicle. No issues other than the previously stated flicker issue. There is a drl bypass floating around that eliminates not only the drl but the flicker issue on start-up. As far as I know there is no harness that solves the problem. I also took my car to my dealer and tried to have them switch the car from non-SSS to SSS in the ECU as there is an option for it but unfortunately it is locked from the factory and cannot be changed.
Old Mar 12, 2011 | 06:51 PM
dyss.'s Avatar
if headlights are the issue, you may or may not have heard of cincity. if you know them, you know they do crazy to casual headlight mods. they have a youtube link also that shows you the different headlight mods they're working on. i would recommend them. they have a good rep too
Old Mar 12, 2011 | 07:22 PM
itsoem's Avatar
Best way is to get an actual retrofit kit where you can put a hid projector on there... cause all you do when you put an hid in a reflector type headlight is scatter the light all around. And it fckn sucks too cause you blind on coming traffic as well.
Old Mar 12, 2011 | 09:12 PM
wiretap's Avatar
The only thing is.. Cincity's lights look like a BMW had sex with an Audi.. there are halos and LEDs all over the place, and they charge around a grand. It's completely retarded. Simple projectors would be nice. Various companies make them for about any other car for around $300. I'd gladly even pay up to $500 for a decent set.
Old Mar 12, 2011 | 09:17 PM
dyss.'s Avatar
right like i said they can do the compelely off the wall outrageous project, but i've also seen, projects very very simple.
i talked to one of their reps and they said if all you want is a simple blackout and have the reflective lights fixed, they can do that. he didn't quote me on a price tho :/
but being that they are popular, you are paying for the name too. so im sure there are cheaper alternatives.
Old Mar 13, 2011 | 11:29 AM
Sir Kyle's Avatar
http://www.theretrofitsource.com/
Old Mar 13, 2011 | 01:04 PM
tehSteve's Avatar
yeah i think i'll pass on 1k to get it done....
300$ > 1000$ to get hids, ballasts, and the antiflicker kit into halogen housing
