Need Help "Avicz130bt and Mito-02 wiring problem"
Old May 17, 2011 | 07:59 PM
MonsterParadise's Avatar
I'm installing my new headunit with Mito-02, and everything work perfectly beside i dont have any sound at all . Spending 4 hours to research, but I didn't find any solution for it. Did anyone have the same problem that can tell me what is wrong? Thanks
Red to Red
Pink to Blue/Pink
Purple to Green/Purple
Yellow to Yellow
Orange to White/Orange
To speakers
Brown is Mute ,Blue/White and Green are unknown...
Bypass for Z130BT
I'm following this video to bypass the hand brake:
http://www.youtube.com/watch?v=xjUq0_hCDLQ
Old May 17, 2011 | 08:28 PM
bobby0283's Avatar
I had a similar problem when I put my Z120 in, I think some of the wire colors are off. Double-check your connections with these diagrams:
http://www.ami-customs.com/index.php...-step&Itemid=4
http://documents.victorytechnologies...duct/17120.pdf
Oh, and there is a better way than that vid to do the bypass. If you use a small flathead screwdriver to pop up the latch on the unit's harness and then lift up the locking mechanism, you can pop the pins out without having to cut the connector. If you're past that part already, disregard...
Old May 17, 2011 | 08:43 PM
Thanks man. I'll look into it. The video show what you just said. I didn't have to cut the connector
Old May 17, 2011 | 08:55 PM
Where did you connect the blue/white (amp turn on)wire to?
It said that
1. Connect the Blue/White wire to the radios amplifier turn on wire.
But I dont know what wire is radios amplifier turn on wire, and I don't see any extra wire from the pioneer power harness
Old May 17, 2011 | 09:20 PM
bobby0283's Avatar
Oh hah I didn't watch it all, thought that was the Soundman vid where he cuts it with a razor. Nm.
IIRC, the antenna/amp wire from the Pioneer harness goes to the blue/white amp turn-on on the MITO.
Old May 17, 2011 | 09:28 PM
which one is the IRC, the antenna/amp wire from the Pioneer harness? IRC = Remote control?
Old May 18, 2011 | 07:03 AM
bobby0283's Avatar
IIRC = if I recall correctly
Check the install manual for the unit, it should have a diagram for "Connecting to a separately sold power amp". If it's the same harness for the Z120, it'll be blue/white on the Pioneer side. Connect that to the blue/white on the MITO.
Old May 18, 2011 | 03:53 PM
Thanks for your help. It sounds awesome :P
manolo2011
Oct 8, 2013 03:45 PM
raytrix
Apr 23, 2011 09:44 AM
satin350
Dec 15, 2009 08:49 PM
