2011 GSR Carputer
Old Jul 9, 2011 | 09:10 AM
  #31
dannylee's Avatar
What's the difference in this vs using an IPAD? I just connect my IPAD to the AUX in and use my phone to tether to get internet also...
Old Jul 9, 2011 | 04:01 PM
  #32
AFD's Avatar
AFD
^^ probably not much different, in theory. Though a CarPC running Windows can run a frontend interface like Centrafuse, that's designed to operate similarly to regular aftermarket stereo/nav units.
Plus, most CarPC setups look more OEM, than just having an iPad hanging off the dash.. but both can get the job done I suppose.
Old Jul 11, 2011 | 06:17 AM
  #33
LOGS's Avatar
Nice work, a carputer is in the plans for me this winter. I gotta figure out how to utilize the steering wheel controls before I start.
=Jason-
Old Jul 11, 2011 | 10:44 AM
  #34
TOralliart's Avatar
Originally Posted by migs647
Well better than having the tactrix plugged into the odbII port, use a ODBII extension cable so you don't kick it every time you get in .
I just unclipped the OBDII port so it doesn't point down. Mine is sitting next to the knee airbag and I have it connected to my carputer at all times.
Old Jul 11, 2011 | 04:10 PM
  #35
kazshell's Avatar
Originally Posted by runm
Does centrafuse sync phone book, in and out calls via BT, allow dialing keypad on screen, and voice dialing? Sweet system btw!
Thanks. Centrafuse does have all that functionality but honestly I haven't used it so I can't say if it works good.
Old Jul 11, 2011 | 04:15 PM
  #36
kazshell's Avatar
Basically what AFD said I didn't want a laptop hanging off the radio or use my phone anymore. With the setup like this I can have all my video, music, nav and everything else in dash
Old Jul 11, 2011 | 04:16 PM
  #37
kazshell's Avatar
Sounds like a good idea I may have to do that too
Old Jul 11, 2011 | 04:18 PM
  #38
kazshell's Avatar
=Jason-
Thanks, if you get the SW controls working let me know I still haven't figured that out....
Old Jul 12, 2011 | 01:05 AM
  #39
JDMCT9MR's Avatar
Wow amazing work!
Old Jul 13, 2011 | 04:11 AM
  #40
Wakewarrior7's Avatar
I don't know if it would work in this application or not, but there are steering wheel control adapters that scoshe makes. It basically hooks into the module on the back of the column and runs to the radio.
Usually they are brand specific for the HU, but there are a few universal one's out there.
Old Jul 13, 2011 | 04:58 AM
  #41
loneracer05's Avatar
That's a sweet set up.I do want to do this oneday to replace my eclipse unit
Old Jul 13, 2011 | 02:07 PM
  #42
TOralliart's Avatar
I don't think the Scoshe one will work. Those are designed for stereos.
There are ones specific to carPCs but I haven't tried them so I don't know if it will work with the Mitsu wheel and how much effort it takes.
http://store.mp3car.com/Joycon_EX_St..._p/com-111.htm
Old Jul 18, 2011 | 07:10 AM
  #43
ukraini9mofo's Avatar
OP
did you completely remove stock HU, therefore you dont have radio at all?
Only reason I am asking is I did a carPC install in my 350z and there was a cubby hole where I intalled my Liliput screen and just wired PC audio output to my AUX in my stock BOSE HU
Thanks
Old Jul 19, 2011 | 10:19 AM
  #44
kazshell's Avatar
Originally Posted by ukraini9mofo
OP
Thanks
Right I removed the radio completely. I thought about just using the aux but there's nowhere to mount a touchscreen, no cubbys big enough anyway. Im sure one could be molded somwhere but I really didn't want to do that.
Old Jul 19, 2011 | 03:19 PM
  #45
TOralliart's Avatar
I ghettoed it a bit.
https://www.evolutionm.net/forums/ev...elocation.html
Might be a bit different in the newer Lancers since they redesigned the cubbies.
