alternator whine in speakers
Old Jul 26, 2011 | 06:14 AM
slebo3213's Avatar
http://www.caraudio.com/forums/wirin...round-rca.html
Old Jul 26, 2011 | 07:39 AM
slebo3213's Avatar
And this if you're really feeling adventurous:
Page 6 post 79 has a step-by-step for repairing/bypassing the Pico fuse
http://www.caraudio.com/forums/wirin...ake-two-6.html
Old Jul 27, 2011 | 02:05 PM
WWGSR11's Avatar
My rcas are on a pigtail. I pulled fuse from factory amp and no whine
Old Jul 28, 2011 | 06:59 AM
slebo3213's Avatar
You did what? You pulled the fuse and the whine stopped? How does that happen?
Old Jul 28, 2011 | 07:05 AM
WWGSR11's Avatar
There's a fuse in the engine compartment 30 amp shut amp off but then no sound
Old Jul 29, 2011 | 06:53 AM
slebo3213's Avatar
Lol. Right. But what we're going for is sound with no whine. Removing the system all together would be a sure fire way to get rid of the whine.
I've got some ground loop isolators that I'm going to try to wire in between the deck pre-amps and the rca's to the amp. They've got their own ground wires, so I'm hoping that this will essentially be grounding the rca's. Will provide updates.
Old Jul 29, 2011 | 02:29 PM
WWGSR11's Avatar
The wires on ground loop isolators are suppose to be grounded. Theres 2 wires on each gli, can i take all 4 wires and put to 1 ground?
Old Jul 29, 2011 | 02:30 PM
WWGSR11's Avatar
The wires on ground loop isolators are suppose to be grounded? Theres 2 wires on each gli, can i take all 4 wires and put to 1 ground?
Old Jul 31, 2011 | 06:58 AM
slebo3213's Avatar
Not sure, but would probably work better if you spread them out.
I tried a fewbthings yesterday and nothing helped. Ordered a new kenwood. If anyone wants a 700bt and plans on running the speakers from it, let me know. Could also be a cheap project for someone.
Old Jul 31, 2011 | 10:15 AM
WWGSR11's Avatar
i tried grounding the gli and no luck still.... ill prob leave them on in hopes its reducing it a bit lol. so frustrating
Old Jul 31, 2011 | 10:39 AM
qwertykerr's Avatar
Dude it's not the aftrermarket pioneer.... it's the factory shiiit. Mine has the wine with the stock rockford fosgate .... it's only thru the AUX input though. CD and radio are fine.
I think on either this forum or evoxforums I read other's have the same problem. Was reading your thread hoping that you had found a fix!!!
I haven't really dug into the problem yet wiring wise.
Old Jul 31, 2011 | 11:18 AM
WWGSR11's Avatar
I heard its the factory amp. The whine is present even when radio is off. I dont use aux. I have pioneer ipod cable
Old Aug 1, 2011 | 06:31 AM
slebo3213's Avatar
In your case it might not be, but my issue is definitely with the HU. Everything else has been pulled out and tested and Pioneers are notorius for ground problems.
Old Aug 1, 2011 | 07:45 AM
WWGSR11's Avatar
Very annoyed. And i cant afford a new nav
Old Aug 1, 2011 | 08:58 PM
WWGSR11's Avatar
factory radio back in and no alternator whine... sending pioneer back to them to hopefully fix problem
