HKS EVC 6 Installation problem
Old Nov 11, 2011 | 09:56 AM
darkstarbd's Avatar
Hi
For wiring the HKS EVC6, you need a TPS input (Pin#10) and a speed/rpm input. but how to get the speed/rpm signal in the Evo X? I mean, in the ecu pinout there is nothing called rpm signal or vss signal. I read that the Evo X has a CAN bus system so there is no separate rpm signal. so can i get the rpm signal off the Coil #1 input (Pin#4)?
Old Nov 11, 2011 | 09:31 PM
AFD's Avatar
AFD
These 2 threads should help locate the VSS wire..
https://www.evolutionm.net/forums/ev...n-sss-gsr.html
https://www.evolutionm.net/forums/ev...rket-navi.html
ORIGINAL PHOTO POSTED BY Guru
VSS should be pin 31 (white w/blue stripe wire) located on the 20-pin connector that's behind the stereo.
Best of luck!
Old Nov 13, 2011 | 12:19 AM
darkstarbd's Avatar
anyone can confirm if the pin 31 (white w/ blue stripe) wire exists for Evo X without factory nav? i have the rockform sound system from factory - no nav
Old Nov 26, 2011 | 02:42 AM
darkstarbd's Avatar
anyways, i am getting a can bus adapter to get the rpm and speed signals so in future can hookup a shift light ar anything else without the hassle
TURBODAWG
49
Apr 11, 2015 02:55 PM
jpsEVO
May 2, 2014 03:50 PM
Uscbryan
Sep 26, 2013 11:59 AM
DuffmasterFresh
10
Mar 17, 2013 10:49 PM
Chebosto
Dec 22, 2009 10:26 AM
