Where to pull Speedo and Engine RPM signal from?
Is there a speed signal and / or seperate Engine RPM signal on the X's ecu?
since it's CAN based i'm thinking most likely not. are people just using first ignition coil for RPM speed and setting their gauges to single signal input?
thinking about installing Defi guages.. thanks
This has been discussed and found in a different thread for the HKS turbo timer type 1. Here is the link for those wires.
https://www.evolutionm.net/forums/ev...o-timer-2.html
https://www.evolutionm.net/forums/ev...et-navi-2.html
I posted pic on there. Here are pinouts:
http://roadraceengineering.com/evox/...-ecuwiring.htm
Had to do em for the AVCR install. Make sure to grab a coil signal for RPM.
darkstarbd
Nov 26, 2011 02:42 AM
