pioneer avh-p2300/axxess awsc how to?
Unfortunately, there's not really a tutorial or anything for that posted up yet.
1st I'd check the factory instructions here..
http://www.axxessinterface.com/steer...ntrol_new.aspx
Think you'll also need to disconnect the factory Bluetooth module if installed (behind the glovebox).
It's been recommended to follow the instructions for the PAC SWI interface as a reference (it won't be 100% the same, but should be similar since it performs the same function as the Axxess)..
http://www.pac-audio.com/swixprogram...ehicles&ID=243
If some pictures of a PAC SWI install into a non-SSS Evo helps, take a look at this thread..
https://www.evolutionm.net/forums/ev...n-sss-gsr.html
Good luck!
Good luck!
